Recommend me a walk...
[Closed] Recommend me a walk in the Peak District
Going out with step-dad for a walk tomorrow. Kinderscout has been mentioned but I seem to remember this is quite flat at the top and a bit boring once you get there.
Can anyone recommend a walk in the hills or perhaps a website I can download a gpx route from?
I think we will be out for about 4 hours.
Posted : 09/09/2012 7:12 pm
Edale > Ringing Roger > Woolpacks > Kinder Downfall > backtrack across Kinder Scout > down Jacobs > Edale is pretty good. Don't follow the crowds and go up the valley, it's quieter and nicer up to Ringing Roger.
Or Fairholmes > Flagstones > Whinstone Lee Tor > Derwent Edge > Lost Lad > back down to Fairholmes is also good.
You'll need to look on a map for either of those obviously, both straightforward to follow though. The Mrs and I did the second one in ± 4 hrs today, it's easy to cut short from Dovestone Tor if you need to.
Posted : 09/09/2012 7:25 pm
Cheers for the suggestions. I'll get out the OS map now and size them up.
Posted : 09/09/2012 7:54 pm
flyingmonkeycorps - Member
I'd suggest doing this in reverse tomorrow, otherwise you'll be battling a pretty vicious head wind on the tops. Some bizarre rock formations up at the woolpacks - well worth a look
Posted : 09/09/2012 8:54 pm
Cheers for the advice. Just put a route into the GPS so should be good to go tomorrow. Its been a while since I've been out in Edale without a bike!
Posted : 09/09/2012 10:23 pm
