Recommend me a mech...
[Closed] Recommend me a mechanical pump for the car
 pnik
Ive got a crappy halfords single barrel that twists more than chubby checker in his hay day, that the hose has perished on, so let out air rather than added last night!
Dont really want anything that requires plugging in or batteries. Occassional use for topping up family cars, used the bike pump in the end but pretty inefficient (bontrager flash!). All the foot pumps seem to be super flimsy these days.
Posted : 12/01/2017 9:08 am
i couldn't find a decent one at reasonable price. Bought a little compressor for a tenner.
Posted : 12/01/2017 10:20 am
I bought a double chamber footpump off Amazon. Being wider, it does resist twisting a bit better.
Posted : 12/01/2017 10:28 am
They've all been pretty rubbish IME. Fail at some point and probably when you need it most. Like Andy we have a little electric compressor. Small enough to leave in the boot and it works really well
Posted : 12/01/2017 10:31 am
 pnik
OK thanks, a double might be a bit better, but maybe a compressor is the way to go, just like things to be mechanical if they can be. Too much is electric/electronic because it can be not because it needs to be.
Posted : 12/01/2017 10:47 am
I just use my Joe Blow for checks and top ups, I've one of the little electric pumps but usually can't be bothered, plus my accessory sockets aren't live unless the engine's running. The track pump would be a bit of a chore if there was much pumping to do though!
Posted : 12/01/2017 10:56 am
as above, get a decent bike track pump - dual purpose!
Posted : 12/01/2017 10:57 am
Never seen that in a car. Usually just need the key in the second position
Posted : 12/01/2017 10:58 am
Probably I'm doing it wrong, it does seem daft. There's no key position, the fob just goes in the hole. The radio works when it's in there so I thought that would count as the "acc".
Posted : 12/01/2017 11:04 am
Is it a BMW by any chance? With ours you need to put the fob in the hole and then press the start button. This doesn't start the engine if you don't have your foot on the clutch. Sounds daft but that is the only way to get the ignition on without the engine running.
Posted : 12/01/2017 11:50 am
Similar process with our Toyota. Press the Start button without your foot on the clutch to switch on electrics.
Posted : 12/01/2017 11:57 am
I bought a footpump for the car - can't remember the brand, but it was a reputable one & wasn't that cheap. It's rubbish. It's a twin barrel, but takes as long if not longer than just using my track pump. And it squeaks like I'm stamping on mice when using it.
I've gone back to using the track pump....
Posted : 12/01/2017 12:02 pm
Yup, that works, thanks. Simple user error/ignorance! It does make the "!" light up and warning gong sound but I view that as an added bonus.
Posted : 12/01/2017 12:05 pm
 Nico
I use a Michelin pump from Halfords. I'm on my second one because the hose started leaking where it joins the body - Halfords replaced without much quibbling. I use it for bikes rather than using a bike pump for my car. My car always seems to have leaky wheels so it gets used quite regularly and it's cheaper than gym membership.
Posted : 12/01/2017 12:12 pm
Get a small electric pump, honestly. I've got what must be the older version of [url= http://www.ringautomotive.com/uk/products/Cars/Tyre+Care/Air+Compressors/RAC630 ]THIS[/url]. You set the pressure you want, leave it running while you do something else, and it stops when it reaches that pressure. It is [b]SO[/b] much easier.
Posted : 12/01/2017 1:15 pm
