New to all this and just bought a brand new rear shock for my enduro 2006
Its a rockshox shock pumped up to right pressure etc.
Came with some bush thingys.
Just wondered how easy it is to swap from the dhx.
Does it just bolt in x2 bolts? Easy?
Stroke length, eyelet size etc all vary from shock to shock, bike to bike. Spesh are renowned for fitting odd size shocks iirc
Ive got the right size just wondered if i can change it myself
Yes then, very simple. Straight swap.
Which do you mean?
There are the metal parts that allow it to take a bolt and space it for the width of the mounts which can generally be swapped with pliers/vice or there is the internal bush which is a thin ring that inserts the shock eyelet. This requires a specific tool to change/fit properly. However that normally comes in the shock. Post a pic of what you have.
