Quick elecrtical sa...
[Closed] Quick elecrtical safty question.
So following on from [url= http://singletrackworld.com/forum/topic/quite-boring-i-need-to-light-a-porch ]THIS[/url] thread I have purchased two LED downlighters, tonight I thought I would get the holes drilled in the (non insulated) roof void. I wanted two lights over a span of 101", so I measured twice, divided by 3 (twice) & cut the holes, first one great, but on the second one I hit a 4x2 joist ๐Ÿ™
So I looked, bearing in mind I'm already through the plastic claded ceiling, & it only looked as if I had gone over by a few MM, so I carried on, turns out I cut out 1/2" of the joist & I needed to go up 3 of the 4" so the lamp fitting would sit in the hole.
My actual question is will it be safe to have a light fitting so close to the joist in an uninsulated outdoor roof void as I have no idea how much heat a 240v 4w led lamp emits?
I'm guessing it will be fine, but I appreciate any experts views on the matter.
Many thanks
2u2r.
Posted : 14/12/2013 8:08 pm
4w ie bugger all.
Posted : 14/12/2013 8:12 pm
Id be happy.
I had a similar thought when i was sticking the, up in a ply roof in the garage. Then i realised my grandad has about 50 of halogens in his sitting room and dining room with his 80s wood clad roof
Posted : 14/12/2013 8:13 pm
Beat me to it!..... Far less then the old R80s.
Posted : 14/12/2013 8:14 pm
Thanks FF, si I take it these house LED's don't produce anything like the heat my bike one does when stationary then?
Cheers.
Posted : 14/12/2013 8:15 pm
If the LED is rated at 4Watts then that's the max power it can consume. 4W is bugger all, esp outside where it's cold and there are draughts etc....
Wood / paper catches fire at 451 Fahrenheit (thanks to Ray Bradbury), which is very hot!
Posted : 14/12/2013 8:19 pm
What's 451F in watts then? ๐Ÿ˜‰
Posted : 14/12/2013 8:22 pm
Martin, got no idea about your lighting, but I did message you about the welly situation. Only girly coloured size nines available!
Posted : 14/12/2013 9:14 pm
Hi Rich, I replied to your message straight away, I think the problem is FB, have you lost my email addy? (It's in my profile)
Cheers.
Posted : 14/12/2013 9:29 pm
