Quite boring, I nee...
[Closed] Quite boring, I need to light a porch?
[#5769634]
Evening all, I have just had a storm porch built (yes it is just a roof protruding out a bit with a wall each end) & I want to light it. I would like to use some kind of sensor to keep it on when it gets dark, but I would also like it not to cost to much to run as I'm tight.
The wife is quite keen on down lighters but I think they could look a little tacky, so firstly what is the consensus on this?
My other question relates to the beam & cost efficiency of the bulbs if I go down this route. I would like it to fill the space with light rahter than look like a spot light, & for it to be a warm light, nothing brash or harsh, so what bulbs would I need & do they do LED (I'm assuming they are the most efficient?) bulbs in soft white colours?
So as always as I trust you lot I'm asking on here, can anyone provide links for the kind of hardware I would need for this little project?
Many thanks in anticipation
Cheers.
Posted : 12/12/2013 10:43 pm
I fitted one of these at my Mum's house a couple of yrs ago.
http://www.hunters-wholesalers.co.uk/steinel-650315-ceiling-outdoor-sensor-light-white-p-48988.html?cPath=63_365_1059
Quality bit of kit and works well. I think it's got a mode where the light comes on at dusk. I put a halogen bulb in it (fairly low power) and the same bulb is still working (the light has soft-start so is bulb friendly 🙂 )
Posted : 12/12/2013 10:50 pm
Why would you light it all the time it's dark ? Why not a pir sensor so it lights when you need it ?
Posted : 12/12/2013 10:54 pm
TR, good question, I would ask the wife, but I know the answer will be "because it looks pretty"
Edit, actually thinking about it having it on between the hours of say midnight & 6am would be a waste, is there some sort of cheap controller you can get to regulate the hours it's on without having one of the mechanical clock type boxes?
Posted : 12/12/2013 10:57 pm
OK, so I will be sort of answering my own question, but say I bought one of [url= http://www.toolstation.com/shop/Electrical/Wired+Timers/Electronic+Wall+Switch+Timer+7+Day/d190/sd2660/p16578 ]THESE[/url], would I be able to use it with 2 LED down lighters?
It says 40w min, 400 max load, I have no idea how much load there is with LED.
Cheers.
Posted : 12/12/2013 11:41 pm
LEDs you are looking at about 5W each max.#
Says not suitable for LED here: http://www.greenbrook.co.uk/products.php?cat=31&nav=4
but wondering if that is means low voltage led or mains? Might be worth calling them
Posted : 12/12/2013 11:58 pm
Naw 40watt min on your timer- will want 8 leds for that timer.
Posted : 13/12/2013 12:01 am
Thank you both, any recommendations before I drive myself nuts?
Posted : 13/12/2013 12:16 am
I've always wondered why timer switches like that even have a minimum wattage; aren't they just a switch, so as long as you don't overpower it it should just work with whatever load you put on it?
I must confess we have a few lights on PIRs and appliances on timers and I've never looked at the ratings...
Posted : 13/12/2013 12:20 am
At least I'm not the only one, I thought it was just a timed on/off switch for 240v 😳
Posted : 13/12/2013 12:26 am
Bump for the morning crowd.
Cheers.
Posted : 13/12/2013 8:55 am
trail_rat - Member
Better still headtorches for all the family...
Posted : 13/12/2013 8:57 am
Well I is well proud I managed to DIY it, just in case anyone searches for the same thing then I used a mechanical timer (to keep TR happy(ish)) into a photocell sensor & then into the 2 LED downlighters.
Thanks for all the replies folks.
Posted : 15/12/2013 5:38 pm
Haha good effort , which photocell did you use , im having issues finding one that doesnt let current leak to the leds,
Posted : 15/12/2013 5:55 pm
You lost me at current leak, but it was a "[url= http://www.ebay.co.uk/itm/Photocell-Kit-detachable-sensing-module-PEC500SP-Greenbrook-/330816591595?pt=UK_Garden_Lighting&hash=item4d063496eb ]knightsbridge[/url]" one.
Cheers.
Posted : 15/12/2013 6:30 pm
Ok thanks will look into them.
Lots of pre led photocells even in offstate let a small ammout of current through - particularly cheap ones found in all in one light units not enough to light a filament bulb but enough to cause an led to light dimly or even flash depending on the point of leak.
So i have two expensive g9 bulbs i cant use in my porch lamps. - ill wire in an external photocell one day 🙂 ill have a look at your knightsbridge one - do you have a rough price as im sure they do a wide range of em.
Posted : 15/12/2013 8:28 pm
The one I used was £9.50 & I haven't seen the bulbs flashing yet, but it has only been a few hours...
Posted : 15/12/2013 9:37 pm
