So these seem pretty bomb proof:
http://www.ebay.co.uk/itm/302329712277?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
However I guess a theft could simply undo the bolts under the van and get access to the bikes that way.. If thats the case am I overthinking it and should just go for a smaller tie down point as if someone has the time to cut away bolts under the van then they are taking whatever they want anyway?
Run a lock/cable through existing loops/holes in the framework?
Swot we do
it's fully boarded / campervan style with a bed over the top of the garage so the ground is only the option
Couldn't you cover the bolts under the van with something that sets hard? Not sure what exactly. Obviously they could probably still chisel away at it but it's more hassle for them.
Yeah thats not a bad option - maybe tiger seal or similar... thinking about it if I use just normal steel bolts (not stainless) I could put a dab of weld on them and then seal them up so they dont corrode...
Think thats probably the answer!
[s]Yeah thats not a bad option - maybe tiger seal or similar... thinking about it if I [/s]use just normal steel bolts [s](not stainless) I could put a dab of weld on them and then seal them up[/s] so they [s]dont [/s]corrode...
After a few months they won't shift anyway!
TBH though.
Someone has found your van
Broken the locks
Found the bikes inside
Realised the bikes are chained up
Figured out that the chain is bolted through the floor
He's either going to give up and just take the iPad and cash they were looking for, or has come tooled up to get that far. If you make it any more difficult they'll just cut the frames and sell the wheels/forks.
or just muller the nuts by tightening them up properly, then trying to tighten them with an adjustable spanner/socket thats a bit too big for the nut - that'll round them off enough to make loosening them off a pipe-dream.
Use molgrips to tighten the nuts.. Round them off in no time
[I]if someone has the time to cut away bolts under the van then they are taking whatever they want anyway[/I]
This. My view is to do enough to satisfy the insurance company to pay out and nothing more. A determined thief will take what they want, regardless of what you do.
Or just ring up your insurers and check your bike is insured in your van. Mines basically chained in the van with a motorbike chain and lock. It's not as easy as breaking in to a shed I guess so that's the start. Plus they'll be after tools I guess before the bonus of a bike.
IHN+1
I use an insurance company that apply 'common sense' - no daft standards of locks, alarms or buildings; they are quite happy with a wooden shed, or locked back door, or locked vehicle....or i am riding it. Then I am covered.
There would need to 2 folk to get them off, one to hold spanner at the top and one to run the nuts off anyway.
After that, what TINAS says, they'll cut through if they really want the bikes.
Use Blind bolts and shear nuts, the spanner flats just shear off when you get them tight enough.
I have them on my Sheffield hoop in the garage.
Do remember if you go crazy they will just take the van.
I know his car maintenance threads are legendary, but that is a bit harsh!
I park the van up against a wall/tree/other immovable object. No side doors to worry about and we have a bulk head. Not perfect, but if someone is that desperate they'll find a way of getting what you have regardless.
As per nwmlarge,
Use shear nuts on the underside if you never want to remove it again.
[url= http://www.ebay.co.uk/itm/SECURITY-SHEAR-NUTS-A2-A4-STAINLESS-STEEL-ZINC-GALVANISED-FOR-SADDLE-T-BOLTS-/122399677444?var=&hash=item1c7f96dc04:m:mq1hyY4zz18GG113rJlwnsA ]Shear Nuts[/url]
Seems academic. If they are in the van and have time to diddle about with bicycles, the engine of the van has probably already been stolen.
Rounding off the nuts is not the answer. There are lots of sockets available to remove such items.
This, therefore make sure the van is hard to pinch.
Use deadlocks on the doors.
If you do bolt through then make sure you go through a chassis member. Otherwise they can just cut out the area of floor that the anchor is bolted to.
I reckon a gang will spend 5 mins tops trying .
Be absolutely certain about what is under where you drill. Grazed the fuel pump with the drill whilst installing a van vault in to an L200 years ago.
Thanks guys - I think I'll go into the chassis and use a security nut like mentioned- I didnt know they existed!
The back door has a armaDlock on it and if they get into the sidedoor (via windows I'd guess) then it'll be hidden by a ply wall to the garage anyway.
The van (citroen relay) has factory deadlocks when you press the key twice so hopefully thats enough to protect the frontdoors with the key plates fitted behind the handles too.
EDIT: whilst on security - are those OBD box protectors any good?
With an 18v angle grinder and a cutting disc, there is very little you can't get through in 5 mins.....
Assuming they're organised and tooled up which is unlikely to start with as either they would have to be specifically targeting your camper van, which could be anywhere in the world today and somewhere else tomorrow. Or they're staking out MTB hotspots and will just take the bike leaned up at the Cafe, or on the roof rack.
And if they are tooled up, they'd just cut the chain, not dick about with spanners!
Id just use a socket head/torx bolt from the inside and a nyloc nut outside - that way you'd need 2 people and hex-keys + spanners to remove it.
The security torx bolts with a pin inside the head are also good.
