my father in law has a Leeds United bottle opener that plays "Marching on Together" every time a bottle is opened. He's hidden all the normal ones.
is there any way to change the tune on this kind of thing?
I'm guessing not, it'll be a fixed little chip. I like your father in laws style!
New patio o'clock.
Yeah, I find a ball pein does the trick.
Put it in the microwave and walk away.
Find the USB socket, plug it into your laptop and reprogram with the appropriate software.
Buy a similar one that plays a different tune. Swap the internals.
What a great bottle opener 🤣
Why on earth would anyone want to change the tune ?🤔
M.O.T 😀
It's likely a cheap "off the shelf" Chinese module like https://astsoundmodule.manufacturer.globalsources.com/si/6008853393703/pdtl/Sound-module/1165590649/Sound-module-for-musical-bottle-opener.htm using an integrated flash memory chip. I doubt there is a USB interface. Mostly likely you'd need to use a magnifying glass to (hopefully) identify a serial or SPI interface. If you're not familiar with these things it would probably be a long and tedious exercise. Probably not worth it unless you are desperate to annoy FIL ๐
Get one from a diffrent team, swap the internals.
RM.
Edit: like someone else already suggested!
Eh?
Is this a Brexit analogy or something?
