Posh watches ?
[Closed] Posh watches ?
 DrP
Well the guy I got my watch from said that he wouldn't use a winder...something about the oils working best one. Warm wrist etc etc..
I wants 100% convinced, but didn't have the knowledge to call BS. Plus, that's just kinda rude...!
DrP
Posted : 23/10/2016 7:44 pm
 LeeW
Spend £3-4k on something that will appreciate 50% plus over the next decade (Rolex etc)
Not many watches will appreciate over that time, Maybe when they're brand new with tags and there's a massive waiting list. Like there is on the new Daytona. Watch tastes change surprisingly frequently.
Best thing the OP can do is go and try some on, in a proper jewellers, not Goldsmiths etc.
I had a friend who used a multi watch winder, the burglar loved it when he carted several of his watches off in a neat carry case.
Posted : 23/10/2016 8:11 pm
 DrP
The caveat here is that I gt my watch my Goldsmiths ( 😉 ) as they actually price matched a jeweller based in the midlands..
I knew what I wanted watch wise, so was looking for the best price from a reputable dealer.
Browns in the midlands had it online (and I suppose, in shop) for just under £2100.
I got goldsmiths online to match it for that price very easily.
Then...I rang Goldsmiths in store and got them to ALSO price match - I was served by the store manager who was very helpful, size it for me, gave me a bit of spiel about 'enjoying it, yes it's expensive but wear it daily etc etc' which was quite nice!
One thing on ostentatiousness..the ruddy boxes these watches come in..man they are OTT!
DrP
Posted : 23/10/2016 8:15 pm
Goldsmiths
oxymoron
??ks??m??r?n/
noun
noun: oxymoron; plural noun: oxymorons
a figure of speech in which apparently contradictory terms appear in conjunction (e.g. faith unfaithful kept him falsely true ).
Posted : 23/10/2016 8:19 pm
 DrP
Well, as in, not some dodgy website selling ohmeega.. 😉
Plus I've never had issue with them before, I'd done my own research etc!
I'd buy from halfords if they had what I wanted cheep cheep!
DrP
Posted : 23/10/2016 8:23 pm
@hebdencyclist - just FYI don't wind your watch that way manually. Your watch is designed to run off the automatic mechanism, and the ability to hand wind is for giving it 10-20 turns to kickstart it if it's run down. There is a mechanism to prevent overwinding as there would be no way of telling when an auto watch is fully wound like a mechanical, but inside the watch is a reversing wheel which is extremely small, and this is what essentially prevents the rotor flying around when you hand wind. This is a complex and very hard working part of your watch - manual winding like that will stress it and it won't do it much good day in day out. It's a known weak point on some watches.
Don't stress about it being off over a few hours, give it a few days of wearing to see how it averages out. If you run your chronograph all the time because you like to see a sweep hand, you will find the watch runs a bit slower, depends on the movement but i'd guess it could be up to 20 secs a day?
Winders are not an issue, some do some don't, in theory an unworn watch will have less wear than if kept on a winder, but it keeps the oils moving around by keeping it running. More important is how many complications your watch has to set up if you let it run down!
Posted : 23/10/2016 8:25 pm
 LeeW
Caveat here is I didn't say he shouldn't buy from them, just try to try some on for size, fit etc.
Buy it from where ever you want, but Goldsmiths have massive Omega displays for a reason 😉
Posted : 23/10/2016 8:28 pm
 DrP
Are they in cahoots then? (Genuine question)
Not that it bothers me one bit as I knew what I was after, so the advertising (there anyhow) didn't 'get me'!
DrP
Posted : 23/10/2016 9:21 pm
Ratadog
I have a Rolex which is 30+ years old. It was a 21st present. I wore it continually for nigh on 25 years until the need to be bare below elbows at work meant that I didn't fancy walking around with it in my pocket as it is now worth more than my car second hand. Still wear it when not at work though.
The elephant in the room is servicing costs. Rolex recommend servicing every 2-3 years as the lubrication used is said to only last that length of time. In fairness, the watch comes back like new with all worn parts replaced. Last time I had it serviced was about 10 years ago and as the glass had a scratch it was replaced as part of the service which then cost around 250ukp.
Cost of service now is 600ukp+ and once the watch is 40 years old that starting price goes up to 1000ukp. As it was playing up and only right twice a day it is off for service but I now have a couple of Seiko solar watches doing duty for work and play that between them cost a lot less than the service cost of the Rolex and should tick for 10 years plus without service. Not sure that I will get Rolex serviced again although I admire the brilliance of a business model that asks you to pay 3k+ for an item without mentioning that you may need to pay the same again every 10 years for the privilege of continuing to use it.
As you've had it for over 30 years you'll be clear on what type of Rolex it is, could you help the rest of us and steer us away from those that need a £600 service very two years?
I'd be glad to clarify that as I've had a 79090 Tudor for over twenty six years but only had that serviced twice so far and I'm now worried that it couldn't be serviced again without buying into a brilliant business model...
Posted : 23/10/2016 10:06 pm
Thanks for the advice - much appreciated.
Posted : 23/10/2016 10:19 pm
they screwed me around.
Didn't notice that the shop was a goldsmiths as it was a pretty old looking place in Guildford and I had been working overnight.
Bought the watch then a cam feel out internally and the watch stopped. Went back, took ages, came back with a scratch on the case.
Went back again for polishing at Omega, came back eventually with deep striations on the case behind the strap.
Went back, Omega said that I had done it when the strap was changed from the standard strap (the leather IS the standard strap on that watch). Maybe someone from goldsmith was practising his polishing technique on it.
Sales guy then said he would get another watch - but the one he got was like some really bad second case that somehow someone had sneaked out the workshop.
More argueing then copied my email to sales of Omega asking what they were going to do to restore my faith in Omega - so a marketing manager stepped in and sent me a new watch immediately.
Posted : 23/10/2016 10:36 pm
Had a lovely Omega which was nicked shortly after all-risks insurance expired.
Looked for replacement, couldn't find what i wanted so got a Breitling Transocean even though i wasn't 100% about it; it's got one dial and one bezel so none of the extraneous stuff which, I think, detracts from the appearance of a watch.
Then saw Omega DeVille which was pretty close to the one which was nicked so - bought it.
Breitling is simple and functional but too big for my personal preference; shirt cuffs don't cover it so it's always visible and a bit obtrusive but there you go.
Elegance and simplicity of an Omega works for me; as for Goldsmiths having big displays of them - same applies to their Rolex displays.
Ian Blowers and Austin Kaye usually have good ranges of pre-owned from several makers.
For something a bit different - Omega Museum pieces.
Posted : 23/10/2016 10:41 pm
Maybe my favourite £3500 watch... despite the date being useless under a shirt cuff. Mixes tool and dress really well. In house movement and beautifully detailed case. Hand wind though, not auto but a 10 day reserve.
Posted : 24/10/2016 12:01 am
Omega Speedy moonphase :
£500+ a service every 5 years, comes back like new though.
£250+ for a new strap, so keep it going with regular saddle soaping...
I take it the moon phase ups the service costs?
Last time my speedie was serviced it was 60 quid.
I had it serviced around 1980 by watches of switzerland, cost 50 quid, but I was on something like 40 quid a week! I had to send it back four times before they regulated it so it was right.
Next service was 1995 and it was 60 quid.
I got it serviced at the watch mender in my high street, he is[was] and old boy who strips and repairs watches in his shop. It needs servicing now.
Posted : 24/10/2016 4:50 am
One of my favourite watches - a Schofield signalman. Hope the link works I struggle with posting images.[url= http://www.ablogtowatch.com/wp-content/uploads/2013/07/Schofield-Signalman-DLC-1.jp g" target="_blank">http://www.ablogtowatch.com/wp-content/uploads/2013/07/Schofield-Signalman-DLC-1.jp g"/> ]null
Posted : 24/10/2016 7:32 am
Here you go
Posted : 24/10/2016 7:42 am
What's the deal with furry straps? To match face fuzz? Seen a few watches with them.
Posted : 24/10/2016 9:11 am
This thread is in danger of costing me some serious money. I thought I'd got over my watch obsession, it appears not.
Posted : 24/10/2016 9:27 am
 DrP
This'll rekindle any obsession!
Look at the detail and tinyness of the bits... LOOK!!
DrP
Posted : 24/10/2016 10:02 am
Him upstairs beat me by two mins!
Posted : 24/10/2016 10:17 am
 DrP
Gotta love the Mash...!
DrP
Posted : 24/10/2016 10:53 am
DAMMIT!
Posted : 24/10/2016 11:18 am
 cpon
[b]davidtaylforth - Member [/b]
Wow, £3.5k; that's alot of money. I think the biggest issue with spending that much on a watch, is not necessarily the cost of the watch itself, but the cost of all the other things in your life.
You're gonna look a bit of a tit with a £3.5k watch if you live in one of those generic Barratt Homes style housing developments on the edge of town and drive anything less than a BMW/Merc/Audi etc.
That's a pretty dim view to be fair. What has the value of your watch got to do with your house or car?
£3.5k could be a holiday, or a bike, or a years worth of fags. None of which have bare any relation to whether you live in a Barratt House or drive an Audi.
Posted : 24/10/2016 11:56 am
[url= http://www.originalgrain.com/products/whiskey-barrel ]Wooden watch?[/url] From the same Mash page.
I saw this recently and really like the look of it.
It's a bit over budget but the OP could consider getting on the waiting lists... It might even appreciate in value.
[url= http://www.ablogtowatch.com/tag-heuer-autavia-watch-2017-heuer-collectors-summit/ ]Heuer Autavia[/url]
For those who have been tempted by this thread, a nice looking watch at a more acceptable price (imho obviously) is this:
[url= http://wornandwound.com/magrette-moana-pacific-professional-gets-updated-pre-order-now/ ]Magrette Moana Pacific Professional - £545-645[/url]
Posted : 24/10/2016 1:17 pm
 Rik
Must say I do like the new Oris Skeleton watch - £1800 though mind.....
Posted : 24/10/2016 1:36 pm
Tudor Black Bay 36?
Steel bracelet, not big, quality brand & automatic.
I have a 34mm Rolex Oysterdate and it never feels too small, it is actually very comfortable. I have had to sell on larger watches in the past as they never felt right.
[url= http://www.iconicwatches.co.uk/tudor-heritage-black-bay-36-79500-steel.html ]Tudor Black Bay 36[/url]
Posted : 24/10/2016 1:43 pm
Someone at the mash must be a member here surely
Posted : 24/10/2016 2:33 pm
Nope, because the mash said £1400 for a watch. That's not even an ok watch, let along a "posh" watch.
Posted : 24/10/2016 2:35 pm
@Captmorgan - whilst Rolex won't service it yours has an ETA movement so any decent watchmaker can service that. Parts like the bezel etc would need he/she to have a Rolex account I think to get the spares.
Posted : 24/10/2016 3:40 pm
I like that Black bay 36, reminds me of the Rolex Explorer with the 5500 movement.
Posted : 24/10/2016 9:01 pm
I have tried on a Black bay 36, lovely size.
However my wallet stayed in pocket, in my opinion the crown sits way too far out with an extra black ring of something, I am confident that would dig in. It's not particularly anti-reflective, not even sure it has an inner coating. Finally it's too thick. I would not be at all surprised if prices go up in the next couple of weeks due to £ shift.
Posted : 24/10/2016 9:31 pm
whoops
Posted : 24/10/2016 9:38 pm
@deepdave, I think you missed the point of my post, I use Rocco from watchworxs and Duncan at Genesis for servicing amoung a few others, I wanted to know which Rolex needed a £600 service every two years.
Posted : 24/10/2016 10:28 pm
 igm
Haters gonna hate, but
Easy to read and I send just enough time abroad that the GMT feature is useful. I have both the stainless and the black nylon deployment straps.
[img] https://goo.gl/images/COKgLL [/img]
[url= https://goo.gl/images/COKgLL ]ORIS BIG CROWN PROPILOT GMT[/url]
PS - I can not get images to work - is it me?
Posted : 24/10/2016 10:56 pm
 Fudd
I think you should budget £600 for every time any Rolex goes in for an official service, and 1k+ for chronograph/Daytona models, but every two years is excessive. Every 6-8 years is more like it but expect Rolex to say otherwise as they have a servicing monopoly to maintain...
The Tudor will be fine as long as the watchmaker doing the work has an ebay or Cousins account, plenty of nos parts still out there without having to resort to Rolex pricing.
Posted : 25/10/2016 2:26 am
 bigG
I'm lucky enough to have -
For when I feel like a git with a big watch, looks OK with casual clothing, but is very out of place with a suit and tie IMHO.
Worn pretty much every day to work
[img] ;w=640[/img]
Work as an every day knocking around watch
I know I don't need that many watches, but I like them so what harm am I doing?
Posted : 25/10/2016 8:20 am
Just bought a Omega Seamaster chrono 300m from Jas at Watches of Sutton, fantastic price and great service. Would definitely recommend you check him out, if a pre-owned watch is what your after.
Posted : 26/10/2016 7:30 am
I'm a believer in a watch must mean something to you, otherwise just buy a generic Casio or Swatch.
I bought one of these when they first came out, with my first salary from my first job, and that it was orange. I still have it and wear it once every 6months or so when I get an urge to wear a watch.
Stock image, but you get the impression.
Posted : 26/10/2016 7:50 am
Page 4 / 4
