Portable Generator ...
[Closed] Portable Generator to Power a Microwave
To power a microwave oven, what output wattage would I need from a generator?
Posted : 21/09/2011 11:02 am
what wattage microwave?
Posted : 21/09/2011 11:03 am
As above - what power is the microwave?
Posted : 21/09/2011 11:05 am
what wattage
classic!
Take a look at the label you will find somewhere on your microwave which tells you how much power it uses. If it's not clear report back with what you find.
Edit - DON'T assume a 750 watt microwave uses 750 watts, check the spec on the label.
I nearly typed 'which watt' but that sounds even worse ๐Ÿ˜‰
Posted : 21/09/2011 11:09 am
