Plywood thickness a...
[Closed] Plywood thickness advice pls?
What thickness to cover stone/wooden (floorboarded) for kitchen/bathroom?
Posted : 22/09/2012 2:16 pm
what's going on top of it- vinyl ?
Posted : 22/09/2012 3:28 pm
As thick as you want, and as thin as you want - if it's being fully supported by stone/floorboards.
Posted : 22/09/2012 3:40 pm
usually use 6mm or 1/4 in-- depending on your view
if the floor is really distorted you may want something thicker.
Posted : 22/09/2012 3:46 pm
Depends entirely on what you're putting on it, how stable and flat the boards and stone are and how you intend to fix it down
Posted : 22/09/2012 5:10 pm
If you're covering it with vinyl, then 6mm will be enough. If you're going for ceramic tiles, then as thick as you can manage (and even then there's no guarantee).
Posted : 22/09/2012 5:19 pm
Dont forget to take all the doors off first,heard of one chap who did a lovely job of laying ply on his floor and screwed and glued all the joints then couldnt open the doors.
Dont forget on a stone floor to use a sheet of dpc plastic to stop the damp in the stone comeing through.
Posted : 22/09/2012 6:12 pm
i guess you are putting down non slip vinyl in those areas , the tiles not come up easy?
Posted : 22/09/2012 6:19 pm
