plumbing track worl...
[Closed] plumbing track world - waste fittings - anti vac valves etc
fill my sink and let it drain - the water comes up in the shower - its lower and it preferentially going there instead of the waste stack - - but drains away slowly while gurgling through the sinks u bend.
I've had the inspection cap off the Stack T piece and looked into the waste pipe with no sign of blockages
i think i have 2 issues here - one the old geezer hasn't fitted a trap to the shower - hes just got the drain straight into a 90degree bend - so will sort that.
second - i need a air admittance valve somewhere -terminating higher than the highest u bend(sink) . - but does it go between the shower and sink wastes or after the sink waste (the system is - shower - sink Tee'd into the shower waste - vented soil stack does it matter *
where does one get an air admittance valve ? would an anti vac trap be what i want ? or would an anti vac u bend trap on the sink alone do the job ?
*i accept that i may well flood my house if i get this wrong but at least my neighbours wont be harmed in the doing so ๐Ÿ˜‰
Posted : 14/10/2013 2:45 pm
 Bear
Simplest thing is to try an anti vac trap on the sink first.
Will probably cure it to be honest.
Posted : 14/10/2013 2:50 pm
cheers - that is the easy route as everything else is destroy bathroom time and im reluctant to- we have lived with it for 18 months and a new bathroom is imminent as soon as we get the hall finished - realistically thats 6 months time - and mrs T-R to be snapped last week , shes had enough for the non draining shower
Posted : 14/10/2013 2:58 pm
antivac traps stopped the shower from syphoning the sink water due to utubing but its still gurgling for air while draining.
phoned a plumber mate this morning and he said AAV on a on the end of a flexy hose T'd into my 32mm piping - stick it in the air higher than the U bend(now the anti vac trap) and that should solve it.
how fun.
Posted : 16/10/2013 10:40 am
