Plumbing (sorry) bo...
[Closed] Plumbing (sorry) boiler fuse keeps going
6 Users
I posted about my programmer having died the other day. Well, got a new one, and now the fuse for the boiler keeps blowing. It runs for a while, in this case though it was only about 2-3 mins. It had a 3A fuse in it, most google people seem to think 5 is more common.
Any suggestions of where to look for a fault?
Posted : 10/09/2013 1:18 pm
Wrong ecu fitted ?
Posted : 10/09/2013 1:19 pm
😆 @ Trailrat
Posted : 10/09/2013 1:25 pm
I'm never going to rise to ECU or overtaking jokes, just for your information 🙂
Anyway, this could be a short thread. Opened the airing cupboard door to put the immersion on, got the tell-tale smell of burnt out electronics. Looks like a tiny leak has been dripping onto the wiring for one of the motorized valves.
Posted : 10/09/2013 1:27 pm
If your boiler includes a pump, then there's a couple of hundred watts there, otherwise there's not a lot else that should draw power, just a few solenoids for the gas valve / water valves etc. I'd have thought 3A would be fine.
Posted : 10/09/2013 1:28 pm
Burned out wiring will do that. Did on ours anyway.
Posted : 10/09/2013 2:30 pm
The connector for the valve was all gummed up with the brown stuff.. I think it'd been dripping on there for a while.
Posted : 10/09/2013 3:10 pm
Sounds like you've self-diagnosed!
Posted : 10/09/2013 4:47 pm
Although not sure why if it was just water in the wires that I'd smell that smell.. maybe water in the motor valve too.
Posted : 10/09/2013 4:54 pm
Water and electrics can do wonderful things, normally arcing or burnt insulation that smells. 240v going to earth is never good though, turn it off, get your leak fixed then look at a new actuator for your valve :mrgreen:
Posted : 10/09/2013 5:02 pm
