Plumbing Help - Loc...
[Closed] Plumbing Help - Lockshield Valve
Refitted a radiator after decorating but didn't get any heat to it. Realised it was the lockshield valve closing when I refitted the cap (it screws into the valve).
Cap looks like this:
Is there a special way to tighten this cap without closing the valve?
Posted : 17/12/2011 7:25 pm
try screwing the screw in while holding the valve head with some pliers without the plastic cap a few times to loosen off the threads so that the friction of the valve is greater than the friction of the screw threads. Maybe even a drop of oil. Then refit and gently screw the screw in with the cap in place.
Posted : 17/12/2011 7:28 pm
Thanks, will give that a go tomorrow.
Posted : 17/12/2011 8:06 pm
You squashed the outside when you turned it off didnt you.?
Have a look and you will see the hole is now oval.
Lightly work it back to round.
Done it myself 100's times, easy mistake.
Posted : 17/12/2011 8:53 pm
