Please help, techni...
[Closed] Please help, technical prob fitting 203mm rotor
I want to fit a 203mm shimano rotor to a set of Judy XC forks. The caliper is a Shimano Deore (single pot) can you tell what adaptor or fittings I need.
cheers
Posted : 29/09/2011 1:48 pm
I think you'll find Judy forks are 180mm maximum rotor size (maybe even 160).
you probably won't die, but you might.
Posted : 29/09/2011 1:50 pm
what he said I would assume that is too much force for that fork tbh
Judy is IS on the fork iirc and I assume deore is post mount caliper [ flat]
In which case a 203 IS to post is what you need if you ignor etha bove advice
WHy so much on such an old /poor fork?
Posted : 29/09/2011 1:53 pm
Thanks, good point Junkyard, its hardly been used. But I may not bother now as it may cuase more problems than it's worth!
Posted : 29/09/2011 2:51 pm
203mm rotor + QR hub.... niiiiice
Posted : 29/09/2011 2:53 pm
I've a 185 rotor and QR hub on an old 32mm legged bomber. No problems for me?
Posted : 29/09/2011 2:56 pm
Judy's were only 28mm stanchions and fairly floppy even with 160mm disks on them.
Still miss my Judy Race forks - 80ish mm of coil plushness in that lovely Boxer metallic red.
Posted : 29/09/2011 2:59 pm
Safer than a 140mm rotor and a QR hub, Xiphon. Think about it. The bigger the rotor the lower the wheel ejection force: less force on the caliper and a better caliper position with a bigger rotor.
Posted : 29/09/2011 3:00 pm
FWIW I tore the disc tabs off a pair of twin crown judys using a 185mm rotor, and before it actually broke it knackered the disc side bushing rather rapidly...
Posted : 29/09/2011 3:47 pm
