Platinum leisure ba...
[Closed] Platinum leisure battery - top up?
3 Users
Mine is from Go Outdoors. I think it came with a little vent tube so I'm assuming it's a vented one. As such it may need topping up, right? It's definitely filled with liquid.
But I can't find where to fill it. There's a label that says 'lift label for maintenance' and there's nothing underneath. It may be possible to prise a cover off but it doesn't feel like it wants to come off.
It will only hold 10.6V no matter how long I charge it. It hasn't been run down any lower than that to my knowledge or run fully flat. Last time I had similar a top up helped a lot.
Posted : 12/01/2022 1:18 pm
Also at 10.6 it's likely that you have a totally dead cell and 10.6 is the remaining cells with a full charge
Also what do you mean you've never had it lower than 10.6 - anything below 12.4 and ultimately 12v is detrimental to battery life and contributory to cell sulphation
most modern batteries are sealed service and do not get topped up.
Posted : 12/01/2022 1:27 pm
I think it came with a little vent tube so I’m assuming it’s a vented one.
It's almost certainly a sealed one - the vent is to release pressure if it's over charged / abused.
You can sometimes prise the covers off to top them up, but I doubt it would be worth it.
It will only hold 10.6V no matter how long I charge it. It hasn’t been run down any lower than that to my knowledge or run fully flat.
It's dead.
Posted : 12/01/2022 3:01 pm
It has never been drained lower than about 12V in use, without load. A damage threshold of 12V seems rather high, most people say 10 or so. It it was left for a few months after it was used though, seems that somehow it's either self discharged too low or something else has happend.
Posted : 12/01/2022 3:12 pm
(From the Powersonic technical manual)
The "safe" level of discharge for typical leisure type batteries is ~50% capacity (so about 12.3 volts off load). They can be taken lower, but it reduces their life. Taking them down to 12V is Not Good.
In any case, they *need* to be fully re-charged ASAP afterwards, or they will sulphate and die.
Leaving it a few months in a very discharged state (~20%?) is almost guaranteed to kill it.
Even if not used, there is some self discharge that means they need to be given a top-up charge every month or two to prevent degradation.
Posted : 12/01/2022 3:25 pm
