[Closed] Phone sd card question.
Have previously downloaded my apple music library to my sd card.
Took card out and wiped/restored my phone.
Put the card back in (which has 57gb of 128gb used so the music must be on there) and apple want me to download all the songs again.
How can i access the music on the card?
It's on a galaxy s5.
If the phone does a linked thing where it sees both storage zones as one then you have probably lost it as it will be there but the way to look up the bytes you need is gone.
Can you see anything if you look at it from a PC as a standard SD card? - change the options to see hidden files
It sounds like the table of contents was on the phone, that is all the indexing to make sense of the files. I'm not sure if the card will have a copy of that which you can reload to the phone. As above make sure on a pc you can see hidden and system files.
