Phil woods Advice
[Closed] Phil woods Advice
Should I go Phil woods kiss hub with eno freewheel or just go hope trials. What to do?
Going to rig it up to a 29er crest.
Posted : 27/03/2013 10:30 pm
do you want bling, or weight? phil are gorgeous and with a WI freewheel will last for ages, but man they're heavy. Hope trials hubs, heavy ish, boring ish,break quite a bit with heavy single speed usage-ish.
Posted : 27/03/2013 11:14 pm
Tazzy, you seem to suggest both options are heavy. Is there a better option (either screw on eg. White/Paul/Surly) or splined (CK/Hope/DT)?
Andy
Posted : 28/03/2013 8:49 am
The Phil hubs are heavy, yes, but mine are still on the original set of bearings after 9 years of pretty heavy use, in all weathers.
I'm on my second WI freewheel in the same amount of time - the original was still running even though it was missing several teeth and the bearing was shot. I've still got the original, which I'll probably rebuild at some point.
For fit and forget durability, I'd get the same if buying again.
Posted : 28/03/2013 10:41 am
White Industries?
Posted : 28/03/2013 11:01 am
Thinking about doing this. Amazing work.
Posted : 28/03/2013 11:20 am
I used the hope hub I found it a light weight reliable hub especially with a light cog.
Posted : 28/03/2013 12:02 pm
Dmr hub, WI freewheel job done
Posted : 28/03/2013 12:17 pm
Are the [url= http://bricklanebikesshop.co.uk/products/blb-superior-freewheel-60-slash-30-clicks ]Brick Lane Bikes[/url] freewheels any good?
Posted : 28/03/2013 2:18 pm
