petrol lawnmower he...
[Closed] petrol lawnmower help
Right,
I have a honda engined petrol lawnmower and havd tried to use it for the first time this year. I started uo after a couple of goes but seems to cut out when cutting grass as if it doesn't have the power
Any idea's?
Posted : 12/05/2013 1:45 pm
have you put fresh petrol in
Posted : 12/05/2013 1:57 pm
My Izy had the same problem - or at least the same symptoms.
I thought petrol line was blocked so massaged that a bit to try to clear it. I believe this helped.
Also, the head if the lead that connects to the spark plug had slipped back on the lead, meaning the metal bit inside the head that needs to contact the spark plug wasn't. I sorted this (slide head of lead to end of cable - you'll see a little circular metal plate which needs to be able to contact the spark plug end, quick rub round inside with sandpaper to clean up little metal plate, reconnect to spark plug, dab of some kind of glue to hold head in place after checking it worked) and then was good to go.
The petrol thing may have been a red herring with mine, but I did it first and felt manly whilst doing so. That said, the problem persisted until after doing the spark thing!
Those are the things I'd check! Good luck!
Posted : 12/05/2013 2:07 pm
Take plug out , look at it , probably corroded from. Winter of doing nothing.
Clean it up with a bit of sand paper
Heat it up with a lighter , stick it back in.
Wil likely fire up straight away.
Never had issue with old petrol, usally store with minimum in anyway and top up with fresh come the new season.
Posted : 12/05/2013 3:06 pm
Yeah, low power is probably a dodgy plug. Cleaning the plug and the lead contacts should see it right.
Posted : 12/05/2013 3:12 pm
Brilliant,
Thanks for the replies, was about to try them out but it started hammering it down, typical!
Posted : 12/05/2013 3:48 pm
