Penetrating oil.
[Closed] Penetrating oil.
For shifting stuck bolts. Anything better than WD40?
Posted : 09/08/2014 4:18 pm
PlusGas
Posted : 09/08/2014 4:25 pm
Your own piss would be better than wd40
Look at 3:1 high penetrant spray ( orange can) ( can be had in bnq)
Or
Plus gas ( usually special order from hardware store)
Posted : 09/08/2014 4:26 pm
Plus gas failed on the drop links on the car. Had to resort to an angle grinder. Bit disappointed as I'd heard it was the daddy.
Posted : 09/08/2014 4:33 pm
Somethings do get corroded so badly that theres nothing in this world will take them off except rotary spanner. But plus gas and heat( oxy/ acetelyne or mapp gun - not boiling water or the ****ing hair drier) is almost as close
Diesels another good one - esp if you can soak the offending item in it over night,
Posted : 09/08/2014 4:35 pm
The other thing you learn when working on old cars is ...if you plan on doing a job at the weekend...stick the high pen fluid on all bolts involved every night for a week previous.
Posted : 09/08/2014 4:36 pm
๐Ÿ˜€ Thought as much.
Also found [url= http://www.instructables.com/id/Make-a-better-penetrating-oil/ ]this[/url] which seems promising. DIY penetrating oil from vegetable oil and nail varnish remover.
My old mechanic recommended diesel and used engine oil mixed 50:50 in a spray bottle.
Posted : 09/08/2014 4:37 pm
RP90 - it's pretty amazing stuff
Posted : 09/08/2014 5:08 pm
Acetone and atff works well too , not a million miles away from veg oil and nail polish remover.
Posted : 09/08/2014 5:16 pm
Halfords shock and unlock spray stuff works very well. Bought some when they stopped selling Plus Gas
Posted : 09/08/2014 5:29 pm
We use stuff at work called kroil, not sure if you can buy it non trade though. Pretty good stuff, works on aero engine LPT bolts which have been running rather hot, for a couple of years usually.
Posted : 09/08/2014 5:35 pm
Ambersil rust flash.
Best stuff I have used yet
Fantastic stuff, but Watch where yoy spray it, you don't want to get a lung full of it
Posted : 09/08/2014 5:47 pm
Go to local car auto parts shop?
Posted : 09/08/2014 6:50 pm
Plusgas for me. PPC magazine did a test a while back and I think more or less tied plusgas and GT85.
Anyone find freeze-release type sprays worthwhile? It always feels a bit homoepathic.
Posted : 09/08/2014 8:10 pm
Try Superslaks http://www.silmid.com/products/arrow-super-slaks-600ml-aerosol.aspx
We use it at work (contains graphite) and is very, very good.
Ben.
Posted : 09/08/2014 9:56 pm
I've used the 50:50 acetone/ auto transmission fluid with great results.
Posted : 09/08/2014 10:27 pm
I tried the freeze spray we get in work a couple of weeks ago. Didn't expect much but it did the job where penetrating oil had failed.
I found the trick was to get it into the rusty threads directly, not to use it as a penetrating fluid.
Posted : 09/08/2014 10:30 pm
Heat the sod up gently (non oil based applications only).
Posted : 12/08/2014 7:43 pm
Penetrating oil doesn't penetrate util you've broken the chemical bond caused by the oxidation. Wallop the offending fitting with a big hammer to shock it free THEN use penetrating oil to help it move, backing off frequently to allow debris to clear from the threads.
Former 1986 Land Rover 90 owner.
Posted : 13/08/2014 8:31 am
 kcal
Fin-Super lube is what I use, but it's not heavy duty really.
Posted : 13/08/2014 9:09 am
+1
Posted : 13/08/2014 9:13 am
Any exposed threads, lay into them with a wire brush.
Posted : 13/08/2014 9:53 am
Been working through replacing a host of bits on my 20+ year old car. Liberal coatings of PlusGas and, equally important, giving it time to work, seem to have done the trick thus far.
Did a full suspension swap without too much swearing - just got the car on stands and gave everything a good coating the night before, as well as first thing am, before starting later in the day. All worked fine and didn't have to resort to hammer / heat...
Posted : 13/08/2014 1:01 pm
I've found Shock & Unlock to be pretty much useless. Best I ever used was Fospro PX but can't find any anywhere. Anyone one know a stockist?
Posted : 13/08/2014 1:28 pm
