PC HELPPPPPP!!!!!!
[Closed] PC HELPPPPPP!!!!!!
Anybody with any suggestions on how to get my 'local network adapter' to work again?
I downloaded microsoft security essentials which promptly disabled it, but not even uninstalling and restoring to an earlier backup doesn't solve it.
Desperate of Northamptonshire
Posted : 20/01/2011 2:44 pm
In what way "doesn't it work"? Symptoms?
With respect, are you sure the cable hasn't come out? (check both ends)
Posted : 20/01/2011 3:06 pm
*deep breath*
Symptoms - big red cross through the network icon, troubleshooting throws up 'local network adapter' not functioning.
I've got bt broadband, they ran through some tests. Reversed and then swapped lan cable, no change. In the meantime wireless connection to same router still works. bt asked about any programme updates, they reckon microsoft programme is the problem, as do the manufacturers techy help.
Posted : 20/01/2011 3:26 pm
 anjs
try risntalling the latest driver
Posted : 20/01/2011 3:31 pm
Laptop or desktop?
Posted : 20/01/2011 3:32 pm
go into the device manager (windows key + pause / break, then go to Hardware tab then click on device manager)
Click on the '+' next to network adaptors, find something that has fast ethernet controller or similar (whichever one has a red cross against the icon or is greyed out) right click and select enable.
Posted : 20/01/2011 3:37 pm
 PJay
It's possible that the Microsoft program left something, or perhaps a registry change, behind that's screwing things up. My first course of action after the uninstall would be to use system restore to roll back to a point before the initial dodgy installaton. Hopefully that'll sort things out.
- whoops, sorry I didn't realise that you'd already tried that. If Bigyinn's suggestion about re-enabling the adapter doesn't work you could try uninstalling it from the device manager, Windows should reinstall it after the next restart.
Posted : 20/01/2011 6:05 pm
What OS? XP?
Posted : 20/01/2011 6:07 pm
What PJay said. Delete it from DevMan and reboot.
I'd be shocked if it's anything to do with MSE.
Posted : 20/01/2011 6:33 pm
pjay/cougar - you beauties! Uninstalled, rebooted, using the PC now ๐Ÿ™‚
Posted : 20/01/2011 8:10 pm
