PC help - new RAM
[Closed] PC help - new RAM
Hi all,
Need 4GB more ram in my work PC. Motherboard is an ASUS B85M-G. This is a list of the compatible RAM from Crucial:
http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/b85m-g
Fun part - I am in India. Can anyone tell me which of these would be suitable (and the cheapest) - from Amazon India? I'm not sure if it simply being DDR3L is enough, or if there is more to be aware of!
http://www.amazon.in/s/ref=s9_acsd_hps_bw_clnk_r?sort=pmrank&node=976392031&srs=3889735031&pf_rd_m=A1VBAL9TL5WCBF&pf_rd_s=merchandised-search-2&pf_rd_r=1B3C3RVPZNJPH2490V3E&pf_rd_t=101&pf_rd_p=0&pf_rd_i=3889735031
Many thanks,
Duane
Posted : 20/02/2017 8:00 am
ASUS qualified DRAM list is here if you want to be extra paranoid:
https://www.asus.com/Motherboards/B85MG/HelpDesk_QVL/
Posted : 20/02/2017 8:49 am
Opened up all the lists, and searched for one of the Crucial compatible RAMs, and it didn't show up on any of the lists!... Confused!
Posted : 20/02/2017 10:39 am
From the Crucial page, I'm assuming the max size of supported modules is 2Gb. So you're looking at something like this:
http://www.amazon.in/Crucial-PC3L-12800-Unbuffered-Memory-CT2K25664BD160B/dp/B005NYOHI
Posted : 20/02/2017 10:48 am
If you click the "view more compatible memory" button, there are 4GB options ๐Ÿ™‚
Posted : 20/02/2017 12:28 pm
If you are in India there are about 500 million people who will claim to be experts and able to help you ๐Ÿ˜‰
Have you had a look inside the box - see what's in there, take out a stick and post a photo - probably 2 of 4 slots used so you will have some options. When I have done similar in Mac I found older chips (slower clock speed) where more expensive but newer ones worked. Also a single 8gb stick was cheaper than 2x4 - as you say a single 4 maybe cheaper than 2x2. Any 2gb's lying around you can snaffle for free ? (I gave a friend an unused 2gb chip you may find similar)
Posted : 20/02/2017 2:49 pm
