PC Help Needed Plea...
[Closed] PC Help Needed Please
My son has a home built PC with an MSI B350 Gaming Plus motherboard. It currently has 16Gb RAM (2 x 8Gb) and he asked for more RAM for Xmas. We did a Crucial Scan and bought the suggested 32Gb upgrade (2 x 16Gb). The PC was working before I fitted the extra RAM but now, it won't boot up. It gets to the screen where you can go into the BIOS and will go into the BIOS but won't from there. Occasionally (but not every time) it shows a screen that say Windows didn't load properly and gives a couple of options but I'm a bit of a luddite and I'm loathe to press any options willy nilly in case I wipe his SSD or something. I have tried all the RAM, just the new RAM and just the old RAM but the outcome is the same. What am I doing wrong?
Posted : 03/01/2021 8:01 pm
Not very helpful, but first, do check the ram is properly seated. I know it sounds silly, but I had this, where I couldnt understand why a new build wouldn't start up, and one of my two ram sticks wasn't properly seated.
My next issue was that I'd not put them in the correct motherboard slots.
Suspect you know more than me, but these are simple things to check.
Also, ram could be faulty - does the machine still boot up if you put the old ram back in place? Do check. if it still does, then try one ram stick at a time, and see if it still boots up. Try both as the single primary to see if either of them are faulty.
Posted : 03/01/2021 8:35 pm
Also check all motherboard conections, you may have knocked one.
Posted : 03/01/2021 8:41 pm
As said check they are in the correct slots, mine has 4 and you need to install them in a particular sequence.
Posted : 03/01/2021 8:43 pm
RAM is properly seated and in all configurations it shows up in the BIOS.
I've tried all slots and an now back with the old RAM in the original slots.
It's currently on a big blue screen that says
Recovery
It looks like windows hasn't loaded correctly
I have two options;
See advanced repair options
and
Restart my PC
Restarting goes back through the MSI splash screen and occasionally flashes up the the Windows lock screen
I've tried a system restore but it didn't complete successfully.
Posted : 03/01/2021 8:46 pm
First, check that you haven't disturbed the SATA cables / power cables to the drive.
Then, boot into MemTest from a USB pendrive. NB it'll run tests continually so once it's completed everything once and hopefully hasn't lit up like a Christmas tree you can just pull the power.
I’m loathe to press any options willy nilly in case I wipe his SSD or something
It'll be fine, everything's backed up right?
If it sometimes boots into the OS, even unsuccessfully, then it might be a bit late for that and we're looking at a reinstall / recovery scenario. But we'll jump off that bridge when we come to it.
Posted : 03/01/2021 8:47 pm
I've just tried a system restore again and it's telling me there are no restore points.
Posted : 03/01/2021 8:48 pm
@cougar it's getting to be outside my comfort zone now...
Posted : 03/01/2021 8:49 pm
Ah, cross posts.
Try "Startup Repair" from there.
It sounds like the new RAM was faulty and it's corrupted the OS install. Leave the old RAM in for now until we get stable again.
Once we're happy, MemTest the new sticks before attempting to boot the OS again.
Posted : 03/01/2021 8:51 pm
it’s getting to be outside my comfort zone now…
Normally at this point I'd say "where are you geographically?", but we're in Tier 4 so unless you can easily get it to East Lancashire...
Posted : 03/01/2021 8:53 pm
Already tried startup repair, didn't work.
Posted : 03/01/2021 8:55 pm
Tried it again, didn't work.
Just did a clean install and that hasn’t worked either. Got to the bit where it needs to connect to the internet and it died.
Posted : 03/01/2021 10:42 pm
Restarted and it’s back at the recovery screen. I’m stumped.
Posted : 03/01/2021 10:44 pm
I don't have Cougar's expertise, but at that stage I'd download "Hiren's Boot CD", burn it to a CD and boot from it. It runs entirely in memory so changes nothing unless you ask it to, but allows you to diagnose the state of the hard disk. It run Linux, but you don't need to know to Linux to use it.
Posted : 03/01/2021 11:04 pm
Could potentially have damaged the ram slot in the motherboard, try with one ram stick, first in slot 2, then 4 if it doesn't work, then the other stick if still no luck. Check your motherboard manual for which are the primary ram slots.
Posted : 03/01/2021 11:19 pm
After trying every other option I finally got a result with an install from the recovery page. Fortunately he doesn't have any important data on there.
Then it failed to reboot... FFS!
Hard reset and it booted OK. Not touching it again tonight, I'm going to have trouble sleeping as it is. I'm going to ask the IT guys at work what they think and proceed from there.
Thanks to all who offered help.
Posted : 03/01/2021 11:53 pm
I will add; at every attempt, the RAM was recognised in the BIOS.
Posted : 03/01/2021 11:56 pm
And it doesn’t shut down properly now. If I select shutdown I get a yellow shutting down screen and the the monitor stops receiving a signal but the cpu fan keeps going.
Posted : 04/01/2021 12:10 am
Long shot, but does he have a Corsair keyboard by any chance? The last windows update broke the corsair driver which resulted in a lot of people including me getting the boot loop of death. If yes, then if you can get in, uninstall the CUE software. It can be reinstalled after but worth googling it quickly as they suggest a few more bits to do after the uninstall ie removing a few registry keys.
*edit* although if you have reinstalled windows then I doubt it's this.
Posted : 04/01/2021 2:40 am
That doesn't necessarily mean anything. Not exactly the same situation but I treated myself to a PC for Christmas. Ran fine at first with the initial 2x8GB. I then installed another 2x8GB and it stopped working. At all times in the BIOS I could see all 4 sticks, all the XMP profiles worked, didn't get any of the motherboard error LEDs, everything appeared fine, it just wouldn't get past the spinning wheel just before the Windows login screen. Occasionally got a Windows blue screen. Turns out one of the new 8GB stick was duff despite BIOS not having a problem with it.
Posted : 04/01/2021 5:58 am
@papamountain it is a Corsair KB & mouse. I will try a different KB & M later when I finish work.
After the fresh install it didn't prompt me to load any software for the Corsair KB & M.
Posted : 04/01/2021 8:15 am
It's was the keyboard software driver getting corrupted so changing keyboards wont make any difference. It's only the Corsair keyboards that have backlit keys i think, K65 k70 etc. It's the CUE software. Keyboard would still work without installing its software, just wouldnt have the software features - key lighting effects etc.
Posted : 04/01/2021 8:21 am
