Morning all,
We have an area at the end of our drive which we would like to get paved to store our motorbikes on.
The space is a square and is about 3m * 3m. It is flat and clear, and drains well.
How much should it cost to get this paved- simple slabs would be fine?
We have been quoted £1k. It seems a lot for a smallish area.
Any thoughts? Recommendations? Surrey area.
Paul
Depends a lot on existing surface and how much prep would be required.
Thoughts - you may need to get planning permission to put a non-permeable barrier over the existing surface (and have suitable drainage added to whatever you add).
Add up the costs of materials (I assume a reasonable depth of footing is required due to weight of bikes on kick stands etc) and then add 2 days labout for 2 blokes plus removal costs of materials dug out (skip will be £150 plus I'd imagine).
Cheers chaps. Quote seems quite reasonable then I guess.
I don't see we would need planning permission. We already have a drive- this is a square of land at the side of the house. We are effectively making the drive a little longer, but behind a fence.
Planning permission to lay slabs?
Potentially, although probably not in the OP's case
https://www.planningportal.co.uk/info/200130/common_projects/45/paving_your_front_garden
https://www.planningportal.co.uk/info/200130/common_projects/44/patio_and_driveway
