Outlook guru help n...
[Closed] Outlook guru help needed
Have been trying to get this sorted for the last two days. I can receive mails but not send them.
Task 'work - Sending' reported error (0x800CCC0F) : 'The connection to the server was interrupted. If this problem continues, contact your server administrator or Internet service provider (ISP).'
Task 'xxx@xxxusing.com - Sending and Receiving' reported error (0x80040126) : 'The operation cannot be performed because the connection to the server is offline.'
Have checked with the ISP, have re-installed MSE, other anti virus software and Outlook communicator. Any help would be much appreciated as I need to send some important docs.
Posted : 19/07/2012 3:03 pm
Depending on what mail server you are connecting to, I reckon you've hit a mailbox size limit - they can be set to restrict sending at a certain limit, but still receive. Delete some mail and try again.
Posted : 19/07/2012 3:11 pm
Thanks for coming back to me mate, tried that earlier and no luck
Posted : 19/07/2012 3:22 pm
As a workaround, try a different email client if you've got an urgent need to send something. This is also a helpful troubleshooting step.
My first thought was that the size of the docs is too large for the recipient email server to accept. Just to check, is it -all- email affected? Can you send simple messages without attachments to that recipient, or to a different address?
Are you using the ISP's SMTP server or something else? Has the ISP changed SMTP settings to require encryption or authentication?
What version of Outlook?
Posted : 19/07/2012 3:34 pm
As an aside,
Running more than one desktop AV concurrently is a tremendously bad idea. Is that what you're doing?
Posted : 19/07/2012 3:35 pm
Am running MSE and Malwarebytes, have never had this issue before but take your point and will disable the later.
Have tried sending a mail with no text to another email address no luck.
Yep using ISP SMTP server and they tell me no settings have been changed on their side.
Posted : 19/07/2012 3:40 pm
Does the ISP have a webmail interface, and can you send from that?
Posted : 19/07/2012 4:35 pm
Not the dreaded 0x800CCC0F ๐Ÿ˜ฏ
Hate Microsoft codes! As it could be 1 of a million things! I would double check your mail settings, a worker had the same thing, and he swears he hadn't changed anything, but things were different!
Posted : 19/07/2012 4:47 pm
Nope unfortunately I have not got access to another webmail interface.
Posted : 19/07/2012 4:49 pm
