I have an old patio area in our allotment made of 90x60 grey council issue paving slabs.
We have a new to us greenhouse to put on them - can you just drill and plug a paving slab then screw the green house down to the slabs?
They wont just crack if i drill them will they - should i drill all the way through them or not?
The expansion of rawl bolts will split the flags. Might be worth making some concrete plugs at each corner(the size of a bucket) that you could bolt to. Or get some railway sleepers and build on top of them. Wind will be your biggest problem.
I drilled the flags and used fixings to attach wooden fence posts to the flags, then attached the greenhouse to that. SLappers probably overkill
Use standard raw plugs and screws, they won't split slabs i've done it a few times.
That's my plan flip. Don't suppose you know what size screws 25mm x m6 or something I presume maybe even shorter?
