OT: Cisco gurus?
[Closed] OT: Cisco gurus?
Totally OT but...
I have a new Cisco 2921 Gateway running IOS 15.4 and a new ISDN interface card.
I've inserted the ISDN card into slot 0 of the 2921 but I'm not seeing the expected ISDN related commands at the prompt.
When I boot the box I can see the ISDN card listed and when I do a "show diag" it's listed there too.
However "show interfaces" doesn't list it and BRI isn't listed as an option when attempting to configure interfaces...
Where've I gone wrong????
Posted : 12/12/2012 10:37 am
Cisco novice here, do you know that that version of Ios supports the new card? If not, it won't know what to do with it.....
Posted : 12/12/2012 10:44 am
The new gateway is on 15.4 and the one that it's replacing was running 12.x and that supported the same model of card, so I think it should support it.
Posted : 12/12/2012 10:51 am
Thanks for the link, I've worked through it but am non-the-wiser.
There's a link to a Software Advisor on there but that crashes part way through ๐Ÿ‘ฟ
After a bit more poking and prodding I think it may be a feature licensing issue, although I've no idea how to resolve it...
Thanks anyhow.
Posted : 12/12/2012 11:43 am
yeah you may not have the appropriate license to use it - do a show ver and it'll tell you what you're on and the next one up.
your level of sfotware probably doesn't support it
Posted : 12/12/2012 12:20 pm
you got a Cisco login for their portal? if so you can check here:
[url= http://www.cisco.com/go/license ]cisco licensing[/url]
and get the appropriate license if necessary
Posted : 12/12/2012 12:44 pm
If you don't have the licensed version then just ring Cisco support and they will advise you on where to get the appropriate license. It's just a case of updating it then and it will unlock the feature.
Posted : 12/12/2012 1:27 pm
Thanks for the pointers. I've passed it on to our IT support guys who are going to contact Cisco.
At least it wasn't me just being a numpty ๐Ÿ™‚
Posted : 13/12/2012 9:26 am
