Old Atco mower proj...
[Closed] Old Atco mower project.
Just picked up a 1960's B23 Atco as a little restoration project.
It's a good runner and cuts very well but is in need of some TLC.
Posted : 13/05/2018 9:52 pm
9 minutes, and you haven't posted the 'before' pics?
Shame on you...
Posted : 13/05/2018 10:03 pm
I've tried but the stupid f***ing mobile version is impossible to use..😨
Posted : 13/05/2018 10:06 pm
Quick! Before I start using google please! 😉
Posted : 13/05/2018 10:11 pm
https://photos.app.goo.gl/eU8xir1Kb4CUClYx1
Posted : 13/05/2018 10:15 pm
Is mower envy even a thing?
I don't even like cutting the grass, but I fancy a project like that one...
Posted : 13/05/2018 11:05 pm
Nice! I took on a 1930s atco. It was an absolute bastard thing with a Villiers 2 stroke. The cretinous heap would happily kick back off the handle and start itself in reverse, when it did run properly, you had to run after it as it was setup to do about 7mph.
Posted : 13/05/2018 11:10 pm
As I couldn't post on mobile, here's a couple of pics:
As it runs well, the first job will be to strip as much of the casing as I can to sand-blast and re-paint. I'll then look to strip the engine to clean/paint then replace the controls/cables to get it up to scratch.
More to follow....slowly probably 😉
Posted : 14/05/2018 9:10 am
Laughing at hot_fiat.  When we first came here our lawns were in a poor state. My dad borrowed a big industrial mower from his work. It had sort of single wheel clutch to help it make a turn at the end of each cut. One wheel would lose drive and the other would whip your ten year old body off the ground to start the next cut. It may have had that clutch on each wheel to turn in either direction.  It also had a moss scarifier which we only tried once. A single pass of the tennis court sized lawn yielded enough moss to fill a skip.
Keep the pics coming OP
Posted : 14/05/2018 10:10 am
That takes me right back to my youth.
My first job was as a lawnmower mechanic.
Those old cast iron engines sound so nice when you get them ticking over really slow with just the occasional ching from the centrifugal clutch.
Posted : 14/05/2018 10:54 am
It does sound lovely, like what I imagine England used to sound like on a Sunday morning all those years ago 🙂
So, should I keep it green? Part of me wants to keep it original the other part wants to make it different...
Posted : 14/05/2018 2:51 pm
If it were me, I'd definitely keep it as original as possible.
I am a nostalgic old Hector, though...
Posted : 14/05/2018 3:03 pm
We seem to be a nation obsessed with putting everything in formaldehyde, from buildings to bits of useless 70s tat (especially mechanical stuff).
Cobblers to that! Steampunk it. Fit an arduodino-based injection system and roots blower then take it racing!
Posted : 14/05/2018 3:18 pm
Keep it green, you could probably make a few quid on it. My dad had a couple of Atcos (he was a poper lawn nut) and they cost a fortune, but when he got rid of them they fetched a decent amount too.
Posted : 14/05/2018 3:26 pm
Think there's a good James May Dismantler episode on an old lawnmower on you tube.
Posted : 14/05/2018 3:27 pm
Started stripping her down last night 🙂
Have got the basic covers off, air filter, exhaust etc so starting the shot-blasting process:
Luckily I have access to a shot-blaster, polishing kit etc at work so that will help with keeping it cheap as I can do most of the work myself 🙂
Posted : 15/05/2018 10:03 am
Pull-start cover cleaned and given a light polish:
Posted : 15/05/2018 12:22 pm
This is very promising - please carry on, stevie!
Posted : 15/05/2018 12:58 pm
Needs James May voice-over!
Posted : 15/05/2018 1:12 pm
I’ve got ever-increasing numbers of cowslips appearing on my ‘lawn’, plus a lot of moss, gives me a good excuse not to mow it. It’s basically just two small squares either side of a path, I just use shears to trim the longer bits.
Posted : 15/05/2018 1:16 pm
A bit more stripping tonight..
Posted : 15/05/2018 9:30 pm
Posted : 16/05/2018 9:07 am
Great project...
there is a guy on the forum below who knows the answer to any mower related question.  I think he may have had a business in the past.. I did something similar and had some help..
https://www.oldlawnmowerclub.co.uk/
Posted : 16/05/2018 9:44 pm
Why can't I see any photo's? All I have is a grey/white no entry symbol. Shame, as I'd love to follow your very cool project OP 😃
Posted : 16/05/2018 9:49 pm
Cylinder bead-blasted and 1st coat of paint:
Posted : 17/05/2018 2:44 pm
no pics showing here either?,
Posted : 17/05/2018 3:49 pm
weird, I can see them. Trying to use google pics...copying the address, pasting in the box etc..
Can anyone else see them?
Posted : 17/05/2018 3:53 pm
No, i can't
Posted : 17/05/2018 4:22 pm
Let's try Imgur:
Start:
Some bead-blasting:
Polished pull-start cover:
More stripping:
Painted cylinder:
Posted : 17/05/2018 4:36 pm
I have to say i'm not a fan of excessive resto jobs!  Leave the patina, but make it mechanically A1
Posted : 17/05/2018 5:26 pm
Nice! 😃  Imgur works!
Thanks
Posted : 17/05/2018 8:20 pm
Yay!  Hooray for imgur!
Loving it, to be honest, I'm impressed and jealous in equal measure....
Posted : 17/05/2018 10:16 pm
I'm not going to worry too much about dents and stuff so it will maintain some of it's battle scars.
Glad you can see the pics now, will continue to use imgur 🙂
Posted : 18/05/2018 2:35 pm
You need to clean all the paint of the edge of the cylinder blades then grind the bottom blade flat and adjust it so it'll cut newspaper as you turn the cylinder by hand.👍🏻
Posted : 18/05/2018 3:09 pm
We've got a cylinder grinding attachment for the cylindrical grinders here at work so will touch up the cylinder then lap the bottom blade 🙂
Replaced the old blade height adjusters with some new, stainless ones.
Posted : 18/05/2018 3:26 pm
Ooh! I acquired an old atco mower too. It’s a bit of a shed (patina, yes definitely patina) and not quite as lovely or collectible as yours, but it’s put some good work in, and the kids love it👍🏼
https://imgur.com/a/J01edmo
Posted : 18/05/2018 6:56 pm
I am liking that! 😎
Posted : 18/05/2018 10:57 pm
Looks like a beast v8 😎
Posted : 19/05/2018 10:50 am
 grey
I've a old Suffolk Punch to renovate as a project.
I really should get round to starting it.
Posted : 19/05/2018 7:36 pm
It is! It has an (optimistic) 12hp on tap! 😱
Posted : 19/05/2018 9:38 pm
If I owned that lawnmower I would just cover it in Chrome plating...the whole thing
Posted : 19/05/2018 10:25 pm
Similar to above, as your blasting and polishing, I'd just go with that as your finish but keeping the blade frame red.
Posted : 19/05/2018 10:56 pm
It'll need painting to protect the metalwork.
Got the bearing plates done overt the weekend:
Posted : 21/05/2018 9:51 am
Bit of ultrasonic washing and a light bead blast:
Before:
After:
Posted : 21/05/2018 1:11 pm
Main chassis nearly stripped. Just need to get the clutch assembly off:
Posted : 22/05/2018 12:17 pm
Managed to throw some paint over the engine. Have stripped/re-blacked all of the bolts & nuts etc.
Starting to look better now.
I know it's not the right colour but I had some HT paint in the shed.
Posted : 23/05/2018 9:51 am
You're cracking on with this - keep the pics coming!
Posted : 23/05/2018 10:35 am
Thread of the week, keep the pics coming
Posted : 23/05/2018 11:19 am
Cheers guys, will update as I go 🙂
Posted : 23/05/2018 1:09 pm
Got the main frame ready to paint. Gave the rear roller a good going over with the orbital sander too, came up quite well:
Posted : 24/05/2018 2:20 pm
I picked up an Allen Scythe late last year, a few bits and pieces and it runs - just about, I think the timing needs tweaking but on a Villiers 25C two-stroke that's a black art and a half! I'll post pics next time it's out of the shed
Posted : 24/05/2018 3:47 pm
Grass bin stripped. Bloody messy job..
http://imgur.com/gallery/biTPQnC
Posted : 24/05/2018 5:33 pm
Repair required on the collector due to quite a few cracks in the steel:
Posted : 25/05/2018 10:28 am
Right, I'm ready to paint 😊
Colour chosen - primer/paint/laquer purchased.
It's going to be green but not Atco green...
Posted : 30/05/2018 7:12 pm
Your ATCO looks like a Suffolk Punch, I suspect that the two companies merged at one point and used that design. Lovely job.
Posted : 30/05/2018 7:17 pm
And we have some colour 🙂 Bonus points if anyone can guess the name of the colour:
Posted : 31/05/2018 11:11 am
Green?
Posted : 31/05/2018 11:48 am
Mallard Green...?
Posted : 31/05/2018 11:59 am
Green - YES
Mallard - NO
Posted : 31/05/2018 12:05 pm
BRG?
Posted : 31/05/2018 12:11 pm
Nope, it's a 90's VW colour.
Got the main chassis primed:
https://imgur.com/gallery/PcYqu07
Posted : 31/05/2018 7:08 pm
Same green as my brothers poorly corrado , dragon green
Posted : 31/05/2018 7:26 pm
just send that corrado to the OP, he'll have it gussied up in no time.
Posted : 31/05/2018 7:42 pm
OOF, that's one spannered Corrado 😧
Posted : 31/05/2018 8:15 pm
Camberwick Green?
Hughie Green?
Posted : 31/05/2018 8:21 pm
Gave the reel a sharpen on the lathe as I couldn't get on the grinder. Stoned the bottom blade flat and sharp too:
Posted : 01/06/2018 3:35 pm
Well, it's certainly sharp enough. Just nearly took the tip of my finger off 🙁
Posted : 04/06/2018 11:53 am
Bit more painting yesterday. Not brilliant but it'll do..Just need to wait for Halfords to get more of the paint in stock...
Posted : 05/06/2018 10:20 am
looking good
Posted : 05/06/2018 10:29 am
Looking a bit more like it now:
Posted : 06/06/2018 9:13 am
That's transformed - good job!
When does it get a shakedown...?
Posted : 06/06/2018 9:44 am
Thanks fadda. Hopefully give it a whirl this weekend..
Posted : 07/06/2018 7:27 am
I think video is required for the first start-up....
Posted : 07/06/2018 9:06 am
That's looking good!
Whatever you do, don't spill petrol on the paint, it'll melt it off almost instantly:-(
Posted : 07/06/2018 9:10 am
Seems a shame to go to all that trouble then not paint it the right green.
Posted : 07/06/2018 9:44 am
Were there any transfers on it? If you have a photo there's a very good bike frame painter in Bury who can recreate transfers, he might be able to do them for you. Neil at Atlantic Boulevard.
Posted : 07/06/2018 9:57 am
I think video is required for the first start-up….
Will try and remember to do one 🙂
That’s looking good!
Whatever you do, don’t spill petrol on the paint, it’ll melt it off almost instantly:-(
Thanks, will be careful 😉
Yeah, I did think about doing it the right colour but, as I'm gonna keep it, I fancied a colour I like B-)
Posted : 07/06/2018 9:59 am
There were a couple of fairly knackered ones. I've found a place that does the stickers for it but thanks for the heads-up 🙂
Posted : 07/06/2018 10:00 am
Bit more assembly..
https://photos.app.goo.gl/dxr1gczVbEmJdGrc9
Posted : 09/06/2018 12:47 pm
Try again, with images..
Posted : 10/06/2018 10:11 pm
