Ni MH battery quest...
[Closed] Ni MH battery question
Just hoping there might be someone on here that knows about these things:
I need to replace a little rechargeable Ni MH battery, which is 4.8V 120mAh
The only replacement I can find is 4.8V 150mAh
Will this work please?
Posted : 04/02/2014 11:30 am
Yes
Bloody hell, that was quick - thanks!
Posted : 04/02/2014 11:31 am
as long as it's physically the same size you should be fine.
It'll last a little longer (say 20%) between charger but take slightly longer (again 20%ish) to charge (assuming charger pushes out a fixed current).
