new drill bit set -...
[Closed] new drill bit set - what's best?
Christmas and all that...
I want a new set and I want [u]really[/u] good ones - no shonky plasticine tat.
What's a good type/brand?
Cobalt gets mentioned a lot - is that the best type?
I'm looking at this one...
http://www.axminster.co.uk/axminster-19-piece-cobalt-hss-drill-bit-set-prod816492/
[general metal drilling, 1-10mm in 0.5mm increments]
Posted : 03/12/2012 11:34 am
I've found these good for making holes in my Defender:
[url= http://www.screwfix.com/p/dewalt-extreme-2-hss-drill-bit-set-29pc/20064 ]DeWalt Extreme 2 Metal Drillbit Set[/url]
Posted : 03/12/2012 11:42 am
Also worth investing in a bench grinder to sharpen and read up in drilling and sharpening technique If its something your doing alot of.
Ps its easy to completely gub a drill bit on a grinder by over heating it and making it soft but get it right and its 100% better than the old throw it away attitude. Saves a fortune 🙂
Posted : 03/12/2012 11:48 am
I normally use dormer HSS, I do use cobalt and they do last better but can be buggered if used incorrectly. £30 seems a decent price and as ever it depends what your usage is. Get you speed and feed rate right and you'll be fine. I use carbide drills down to 0.1mm and so am very careful with what they are set to, its not so easy with a hand power drill but with a pillar drill you should try and get close to the correct speed if you can, it will certainly mean your bits will last longer.
I have some bergan tools seems good enough , not special but durable.
Set of circlip pliers, impact driver sockets and socket racking
No experiance with drill bits but i wouldnt hesitate to buy em.
Posted : 03/12/2012 11:53 am
yep, got a bench grinder and pillar drill - just the current set is old and tired now so needs replacing really. The bigger bits are okay but 2-6mm are well used.
I bought some cheaper HSS recently and was very unimpressed, so I'm happy to spend a bit more this time.
If you need a set have a look at these;
http://www.drill-service.co.uk/Product.asp?Parent=220200000000&Tool=366
I would buy a few spares in the more commonly used smaller sizes (I can't sharpen anything less than 3mm very well)
Posted : 03/12/2012 11:54 am
Don't think you can go far wrong with Dormer IMO.
Posted : 03/12/2012 7:51 pm
Try Beal UK, they are usually really good value. I find using a drill press and cutting oil preserves the life of a drill bit.
http://www.beal.org.uk/drill-bits-abrasives/cat_42.html
Posted : 03/12/2012 8:48 pm
 Taff
I've got two sets of Draper and they have done well so far
Posted : 03/12/2012 8:53 pm
Cobalt! Have a guy at work who does all the drilling to fix the brackets to the steel for the Brickies and every hole is drilled with a cobalt bit! No piloting, no cutting compound, straight in with a 5mm.
Posted : 03/12/2012 10:13 pm
