Networking help (pl...
[Closed] Networking help (please)
HI
Here's the setup:
[b]House[/b]: Belkin router providing wifi throughout our house.
[b]Reception [/b](60m from our house) - TP Link router connected via Ethernet cable from the house and providing internet access on a PC over there,
Also connected to the TP Link router is a Belkin Wireless Access Point to provide wifi within that specific area.
[b]Problem[/b]: Although I can connect to the WAP in recepption and access the internet most of my guests can't. They can see the WAP and are connected, it just won't let them access the internet.
Any ideas?
Ta
TS
Posted : 26/08/2011 11:45 am
Just to add to the above - it did work when I initially set it up and I've reset everything with no success.
Posted : 26/08/2011 11:48 am
Ping the IPs of the different devices, that'll tell you where it's failing.
Disable wireless security temporarily as a troubleshooting step. Don't forget to re-enable it afterwards!
Try changing the channel used by the WiFi.
What's different between you and them? Are you on XP and they're on W7? PC and Mac? iPhone?
Posted : 26/08/2011 12:16 pm
does that mean some can?
Posted : 26/08/2011 12:24 pm
Ooh, well spotted.
Posted : 26/08/2011 12:29 pm
Cougar - how would I ping the IP's? No wireless security 8O. I'll change the channel.
I can access it on my Iphone and my laptop (XP). Most people are using smartphones - Iphone primarily.
uplink - yes.
TS
Most people are using smartphones.
Most people can't access the Internet.
Are they the same 'most'? Ie, is it exclusively a smartphone issue?
Can you test to see if an affected guest device works in the house?
On an iPhone, I've no idea, sorry.
Posted : 26/08/2011 12:37 pm
There's an app for the iPhone called "Network Utility" that lets you ping, port scan etc
Edit: here you go
http://itunes.apple.com/us/app/network-utility/id308218551?mt=8
Posted : 26/08/2011 12:54 pm
I had a similar problem with a belkin router - sometimes could connect sometimes not with pc no.2 and smartphone. It was resetting the privacy settings all the time though weirdly the main pc remained unaffected. In the end changed router - end of problems.
Posted : 26/08/2011 12:58 pm
 Tom
If you have a cable going into the Internet port on the router or WAP, try moving it to an ethernet port instead.
Posted : 26/08/2011 1:03 pm
If your gear connects and works, but the guests stuff doesn't then:
- have you got a "Access Control List" set up on the router (i.e. a list of allowed devices). You'd need to turn that off.
- are you sure the guests are connecting to the right router (i.e. not hitting a neighbours wifi by mistake, have you set the SID to something obvious?).
Posted : 26/08/2011 1:11 pm
Is your WAP trying to give out DHCP addresses as well as the Belkin?
This is a good guide [url= http://www.unix.ms/netgear ]Extend your wireless range[/url] , it's not exactly what you are doing but the principal is similar.
Posted : 26/08/2011 1:16 pm
Thanks for all this folks, I've got more to go on now.
GrahamS - there are no neighbours here ๐Ÿ™‚
TS
I eventually got someone into the house to try our wifi here. Rebooting the router in the house fixed the problem!
TS
Posted : 16/09/2011 9:59 pm
