Community
Need a new stovetop...
[Closed] Need a new stovetop coffee pot!
I'll chalk this one up to being over tired, as with every other stupid thing I do. I've just put the stovetop on, but didn't realise I hadn't put any water in the boiler 😒😐
<span style="font-size: 0.8rem;">I did realise once the kitchen started to fill with fumes instead of nice coffee aromas! I picked it up with an oven glove, the handle melted off, I chucked the whole thing in the garden. I'm pretty certain it's ****ed. </span>
Anyway, I've just seen the bialetti brikka pot. Anyone used one of those? Is it worth getting one over the standard bialetti?
Posted : 13/11/2018 8:56 pm
Bialetti obvs cos spares etc.
I prefer the stainless ones for easier to clean, and compatibility with induction hobs.
Posted : 13/11/2018 9:27 pm
 Pyro
The Ikea stainless one is decent enough. It's a big debate as to whether the Brikka is worth it, some say yes, some no.
Posted : 13/11/2018 9:34 pm
I have done that before, forgetting to put water in, then putting it on full power on the induction hob. I discovered that the hob has some sort of thermal protection, so cut out when it got too hot. The Moka pot has a few black marks, but still OK. The hob worked fine after cooling down.
Anyway, +1 for the stainless Bialetti. Easy to keep clean, and maybe less of the alu taste. Plus it works on induction, the alu version doesn't.
Posted : 13/11/2018 9:41 pm
+1 for stainless bialetti, really like mine
Posted : 13/11/2018 10:07 pm
 nerd
The Brikka is better than the standard Moka Express.  It produces slightly better coffee but is more consistent.
Get the 2 cup one, not the 4 cup.  I've only used the 2 cup but I've read that the 4 cup doesn't produce as good coffee as the 2 cup.
Posted : 13/11/2018 10:09 pm
Bialetti spares will also fit many copies, so you may be able to resurrect the one in the garden.
Posted : 13/11/2018 11:12 pm
The one in the the garden is a bialetti Moka (one cup.) I'll go and check it out in a minute. The handle has melted off and I assume the Gasket is toast.
Had a quick look to see how much a direct replacement is but saw the brikka. I've never heard of that one before so kinda fancy trying it. Luckily I have a three cup Moka as well to keep me going!
Posted : 13/11/2018 11:27 pm
Get a Bialetti and get one quick. Plus spares. Looks like the home coffee machine / pod machine boom is killing them.
Posted : 14/11/2018 4:34 am
I think there will always be stove-tops available.
The pods are environmentally unfriendly and will eventually get banned. It started with German state governments refusing to have them in govt buildings. The figures are a bit crazy, ~13g of aluminium waste for 7g of coffee.
Posted : 14/11/2018 9:11 am
love my Moka. its only a non branded steel one, charred and stained from excessive use. we upgraded to a fancy nespresso machine once but that just gathers dust - apart from the milk frother bit...
btw. i have recently taken to filling the bottom up with hot water from the kettle before i put it on the stove - this way the jug fills up with creamy hot nectar almost instantly rather than having to wait 10 / 15 minutes!! is this sacrilege??
Posted : 14/11/2018 9:13 am
True. But perhaps not Bialetti's!
Posted : 14/11/2018 9:18 am
Thinking about getting one of these.. couple of questions if anyone could help?
I presume I could make regular strength coffee (not espresso) if I bought a 6 cup version, then just used less coffee / more water?
Also are they a pain to set up / clean? Finally, how long roughly do they take to be ready (if I use mahalo's method of using already boiling water)
Thanks in advance
Posted : 14/11/2018 9:26 am
I’ve got the 6 cup Bialetti one, use it twice a day. I Know how much coffee to grind to make one long coffee out of it that isn’t too strong.
It takes 8-10 mins to make. Whilst waiting I make the rest of breakfast.
No problem cleaning either.
Posted : 14/11/2018 9:36 am
I did the same thing with my Bialetti stovetop. It actually looks pretty cool now with the blue/yellow colouring, but the heat did mess up the spring in the pressure relief valve. Sadly, Bialetti do not sell those as spares any more, so I will either have to find a way to fix it, or buy another.
My Bialetti Moka pot takes about 5 mins. Makes half a mug of very strong coffee which I then top up from kettle. Tried the hot water in the bottom once, the burn hurt so just use cold now. Cleaning takes 30s.
Posted : 14/11/2018 9:50 am
yeah mine tends to get left until the next time i use it - so i bang the old brewed granules into the bin and give the filter & jug a little swirl under the tap, thats about it.
Posted : 14/11/2018 9:58 am
just ordered a 2 cup Bialetti one.  I will be using preground shop bought expresso coffee.  If I make a 2 cup volume, does watering down with hot water from the kettle work to make a longer one ?
Posted : 14/11/2018 9:59 am
Yes, same here.
Brand doesn't matter much - they all work the same and take the same seals.
Bialetti Venus 4 cup is still only about £25
Posted : 14/11/2018 10:21 am
Yep, you can do that. I tend to use a big slug of hot milk, the volume of coffee from my 3 cup pot and a splash of water to top it up. Or I'd use my one<span style="font-size: 0.8rem;"> cup pot to make something like a macchiato.</span>
As above with cleaning. Dump the used coffee and rinse under the tap, nothing more to it.
As for setting it up, yeah it's a bit more time consuming than making instant coffee or using a Tassimo or whatever. But it's a satisfyingly clunky piece of kit to use.
Think the one cup pot is a write off, the handle melted off and there's molten rubber all over the inside of the threads. The boiler unit smells of burning as well!
Might see if I can get a brikka as an Xmas present! 😜☕
Posted : 14/11/2018 10:31 am
