NAS drive expansion
[Closed] NAS drive expansion
I have a Readynas duo v2 with a single 1tb drive. I want to add a 2nd drive to mirror the 1st. Do I need to match the drives or can any compatible drive be used. Thinking of spin speed, data rate etc.
Posted : 17/10/2012 10:58 am
My understanding of mirroring is that it's fine to use different spec disks, but that your performance will be the performance of the worst disk.
Hasn't been a problem for me (now a ReadyNAS user, but also on previous RAID arrays) as there tends to be a year or so between the disks I buy, so it's the old disk limiting me, not the new one!
Posted : 17/10/2012 11:00 am
Does a 5400rpm disc typically have a worse performance than a 7200 disc then-excuse the numpty questions. I don't know what disc is fitted at the moment.
Posted : 17/10/2012 11:06 am
Typically, yes. But this may not matter to you. For example, a 5400 will still stream movies and music fine.
You *may* notice a difference if you are transferring either very large files or lots of small files either from or to the disk.
What do you use the NAS for?
Posted : 17/10/2012 11:20 am
Streaming Music (flac files) to a squeezebox Mainly,some files backed up on there too.
Posted : 17/10/2012 11:46 am
Either rotation speed will be fine. A 5400 would of course take longer to mirror the existing drive than would a 7200 (assuming the existing drive is a 7200) but I don't believe you'll notice any difference once up and running.
For your usage, I don't believe disk speed is a necessary concern, I'd be looking at disk reliability as the key factor instead.
Posted : 17/10/2012 11:58 am
Don't buy the Western Digital Green drives, they don't perform very well. Go for WD Red drives, work very well in the ReadyNAS.
Posted : 17/10/2012 12:01 pm
Milkie, ta very much, those are the 2 I'm looking at. Markie-thanks for the info, just what I needed
Posted : 17/10/2012 12:15 pm
All other things being equal, yes.
However, all other things are rarely equal.
Posted : 17/10/2012 12:31 pm
