My laptop won't loa...
My laptop won't load any Web pages (edge).
Have tried everything but edge browser won't load any pages. Have reset my broadband and tried troubleshooter but it cannot find anything wrong when I test. Things like steam good old games apps etc work fine as do my consoles and mobile (connected to my wifi).
I  have Windows 10 on my laptop and use Microsoft edge browser.
I don't  have a clue what to do tbh as I cannot contact Microsoft support on laptop as no Web pages will load.
Thanks in advance.
Posted : 18/10/2023 8:33 pm
Airplane mode? What do the icons on the bottom right look like? Screenshot would be helpful to start. <br /><br />
What happens when you type www.bbc.co.uk into the search bar - eventually it will either load a page or time out with an error?
EDIT - STW is (un)helpfully putting the http:// in front of that web address, that’s not how I typed it and it won’t edit out. Don’t bother typing that bit just start at www.
Posted : 18/10/2023 8:44 pm
Not changed any settings at all (wifi is on and never had aeroplane mode on). It was working fine yesterday but now it just won't load any Web page at all. I downloaded brave browser from Microsoft app store to try but that also won't load anything at all.
Edit am replying via my mobile phone as cannot on my laptop.
Posted : 18/10/2023 8:52 pm
Are the date and time correct on the laptop?
Posted : 18/10/2023 8:54 pm
Open a command line/terminal and type "ping BBC.co.uk"
See what it returns
Posted : 18/10/2023 8:55 pm
Yes date and time both fine.
Posted : 18/10/2023 8:56 pm
Sharkbait ah Apologies no idea how to do that?
Posted : 18/10/2023 8:59 pm
https://www.digitalcitizen.life/open-cmd/
Posted : 18/10/2023 9:01 pm
Used to type "CMD" into the start menu run window...
May be different now.
Posted : 18/10/2023 9:02 pm
Ah thank you. I typed that into command prompt "ping Bbc.co.uk" but it replied is not recognised as an internal or external command,operable program or batch file.
Posted : 18/10/2023 9:07 pm
Don't quote the command 🙂
Posted : 18/10/2023 9:08 pm
Ldoh apologies (I am a complete numpry when it comes to anything PC tech).
Yes got a ping back 4 in fact 8ms. 8ms. 9ms and 10ms no packet loss.
When I try to load a Web page it just replies closed the connection err_connection-closed
Posted : 18/10/2023 9:12 pm
Have you got any VPN clients running? Stop them if so, try again?
Posted : 18/10/2023 9:17 pm
No vpn at all do I use.
Thank you all for helping I must add this is most confusing why this has happened tbh.
Posted : 18/10/2023 9:20 pm
Can you have your phone as a hotspot and connect your laptop to that, rule out the network at least
Posted : 18/10/2023 9:21 pm
We’ve had something similar at work following an update, sorted by repairing Edge so could be worth a shot.
Go to Control Panel/Programs and Features or open start menu, type appwiz.cpl and press enter. Find and select Edge then look above the program list for an option to Repair (or change then select repair) and let it run.
As woody2000 worth trying on a different network to help narrow it down.
Also, have to ask (sorry) have you tried turning the laptop off…
Posted : 18/10/2023 9:47 pm
leffeboy and leffeboy reacted
Have repaired edge and turned laptop off and on about 20 times now lol.
Not tried the mobile hotspot with my mobile but will try that.
I did manage to load yt earlier but then it got disconnected again by browser. Checked firewall also and deleted then added edge to it but no cure.
Just tried mobile hotspot with my phone and still cannot load Web pages (my laptop still wont  load Web pages I mean)
Posted : 18/10/2023 10:16 pm
Have you tried Chrome (if you have it) ?
Posted : 18/10/2023 10:56 pm
I don't have chrome as cannot find on mic app store but did download brave browser same thing happened no pages load.
Posted : 18/10/2023 11:00 pm
Also type this into a command window you will need to run it as administrator
netsh int ip reset
Posted : 18/10/2023 11:04 pm
I did that and it did load singletrack forum page but then it has gone right back to not loading any page/cannot reach this page.
Gah!
Posted : 18/10/2023 11:29 pm
Delete all the cookies/browsing history too.
Posted : 18/10/2023 11:45 pm
If it's doing it across multiple browsers I'd be looking at running a virus/malware scan.
System Restore?
Posted : 18/10/2023 11:49 pm
I would also try turning the firewall off/resetting it. From an earlier post you said you have added Edge to it. If you have been tinkering in there you may have disabled something….
Try the netsh command again and restart the device if you didn’t do that before…
Posted : 18/10/2023 11:51 pm
Use firefox with an addon with a name that cannot be uttered here, for it is the language of dark lords.
On mobile, just use Opera.
Posted : 18/10/2023 11:53 pm
Other support options are going to be too complicated to explain via a forum from my mobile at this point. Try a scan as Cougar suggests.
Posted : 18/10/2023 11:57 pm
Try opening an “in private” window in Edge. This disables third party extensions and cookies.
Posted : 19/10/2023 12:22 am
**** edge. use firefox.
Posted : 19/10/2023 1:07 am
Always worth running system file checker to check for any weird corruptions that maybe hiding.
Open Command Prompt (elevated) and type sfc /scannow, it'll run through and check and fix any issues, then restart the laptop for good measure. Sometimes find if I've got a bizarre issue that you think would be unrelated running this fixes it.
Posted : 19/10/2023 10:52 am
again thanks for all your help.
unfortunately nothing has fixed the issue (have done everything that you all have recommended).
have made an appointment with a pc repair man to come and look at the laptop (between £59 to £69 they quoted us gulp)
i bet it is an easy fix for someone who knows what they are doing lol
i blame bill gates and microsoft for my laptop shenanigans (waves fist furiously 😀
Posted : 19/10/2023 6:00 pm
Firewall reset?
Type the below in a CMD window (run as administrator)
netsh advfirewall reset
Posted : 19/10/2023 7:18 pm
unfortunately didn't solve the issue.
i am completely stumped as to what is causing this?
sometimes the page will load when i try it (for a few seconds0 but then it will then go to the screen and say took too long to reach address or address closed communication or words to that effect.
Posted : 19/10/2023 8:26 pm
Netsh winsock reset
followed by
ipconfig /flushdns
then restart.
(I don’t believe it’s a DNS issue as you were able to ping bbc.co.uk but no harm in flushing the resolver cache. 🤷‍♂️)
one final thing… do you have an Ethernet cable? If so, plug your laptop into the back of your router using the cable and try that way…
Posted : 19/10/2023 8:32 pm
unfortunately still no dice as they say.
this should be a test on the krypton factor tbh 😀
sometimes it will detect a network change the browser but tbh it takes a while loading before it says that then the same thing happens (took too long to respond/ timed out etc)
Posted : 19/10/2023 8:48 pm
Tried the Ethernet cable?
do you have an Xbox? If so try the web browser on that.
Posted : 19/10/2023 8:50 pm
can you create a new account on your laptop and try Edge in that?  It doesn't fix your problem but if it works tells us that the problem lies in your account rather than outside in the router or the wifi
my xbox browser is fine along with my laptop i am using now to reply etc. also my mobile is fine too surfing the web etc.
looks like i will have to wait for the man to look at it on wednesday.
again thank you all for your help with this issue 🙂
Posted : 19/10/2023 8:52 pm
Where are you geographically? I'll do it for nowt if you can get it somewhere in the vicinity of East Lancashire.
Posted : 19/10/2023 9:05 pm
that is extremely kind of you @cougar but i live in devizes wilts so a long way away. no worries good sir i will get the issue solved one way or another (even if i have to resort to shouting 🙂
Posted : 19/10/2023 9:19 pm
I had the same issue, quick search found it was a known issue but like here there were loads of suggested ways to fix it.
For me I just rebooted my router and it all worked fine after that.
Posted : 19/10/2023 9:27 pm
Reset Edge?
Open Edge.
Click the 3 dots in the upper right side of the screen.
Go to settings.
Reset Settings
Reboot.
NOTE!! That will clear all Edge settings including cookies, history and saved passwords.
Posted : 20/10/2023 3:21 pm
Can you put a portable browser or the install package for a browser on a usb stick or something to get it from your working laptop to the one with the problem. Then install the alternative browser and remove edge? Then reinstall?
Edit: only saying that as I'm not sure how 'stuck' you'd get if you uninstalled your only browser. I'm sure windows would just try to replace it for you but I've never tried.
Posted : 20/10/2023 3:29 pm
when i tried going online today on the laptop it loaded the pages fine for about a minute but then the issue returned and no pages can be loaded again.
i have reset edge settings but still cannot load any pages.
not a flipping clue what is causing this at all?
again thank you all for the replies and help 🙂
Posted : 20/10/2023 7:24 pm
edit:deleted
Posted : 20/10/2023 8:41 pm
Alright.
Would you like me to look at it remotely? Assuming it's just web pages and you still have actual Internet connectivity (which would appear to be the case from sharkbait's ping test) then we could set up a TeamViewer session at some point.
Posted : 20/10/2023 8:45 pm
bails and bails reacted
@cougar that would be very kind of you thank you (when it suits you to do it as no rush).
how do we go about doing the remote thing?
thank you again 🙂
Posted : 20/10/2023 9:02 pm
Download TV. You might have to do it on another machine and stick it on a USB pendrive.
https://download.teamviewer.com/download/TeamViewerQS_x64.exe
Once installed it'll give you connection details that I'll need. The other way is if I send you a link, but that might not work for the reasons we're doing this...!
When is another matter entirely.
Posted : 20/10/2023 9:16 pm
Make sure you tell us what the problem was one of you…🙂👍
Posted : 20/10/2023 9:17 pm
will do @cougar have just downloaded it to a usb stick thank you 🙂
i will def let you all know what the issue was when it is sorted as i would like to know myself what the heck it is lol.
Posted : 20/10/2023 9:24 pm
