I'm not overly electrical but after the Dyson sounding a bit 'strained' then finally dying I predicted the motor has gone. Only on the basis of changing the fuse and nadda happening when you switch it on.
Looked on fleabay and motors are available for about £21 - £40, so is it a case of unplug the old one and put new one in?
Anyone done it and is it basic DIY stuff or has Mr D fitted lots of clever things to thwart the savvy owners…?
Swapping out the motor is quite easy. I've repaired the on/off switch in one...
Have a google for some online instructions.
Yup; basic DIY job on a DC07. I did try replacing the carbon brushes (£2), but it fireballed, so new motor was the next step. Also needed to spend an extra £2 on a long reach Torq driver.
Isn't the standard reply to get a call out for the hateful machine & make the it as new for about tuppence halfpenny?
I fitted a replacement clutch mechanism to our older Dyson in the hope of rejuvenating it; it didn't work (still sucked like an athematic geriatric) but it wasn't _too_ tricky. I did need a long handled Torx screwdriver to get at some of the screws, and the clips and so on were a bit fiddly.
If you need to remove the belt, there's a relatively useful tool to do that too (which I'm sure I no longer require, if you need one).
As for a motor though, I don't know. It all seemed quite well put together TBH.
Have you googled / YouTube'd for the appropriate procedure (bearing in mind there are many diff models)?
Hi, yes I have replaced the motor on my Dyson. It's straight forward enough, most difficult part was getting the wheels off!!! I think I found a guide on how to do it from Google. Not sure which one you have. Dyson also do repairs but I don't know how expensive it is.
Have a go,it's nice to make something work again. Good luck 🙂
Give it a few hours somewhere cold...
Our Bissell used to get hot & cut out. Eventually it would work again.
I can only think it must have some kind of thermal cut-out.
Either way, it started making a horrendous racket & smelling badly so I put a new motor in last week. As good as new now. Was no more difficult than wiring a plug. Just lots & lots of screws.
And in terms of sucking power, the Bissell is in a different league to the Dysons we've had...& binned.
I will now! Got a long handled torq driver so may rip it part and have a look..
Having seen this I wouldn't trust a Henry:
