I've had no problems with my neighbours since I locked them in my cellar.
Four months ago.
Why should it be the neighbours problem? If the remote is buggered then its yours. If its his car then its his. It not one or another at the moment. Just get it checked out at the car supplier. Me, I'd be worried about what else may be happening. Cloned remote? It can happen.
PMJ, round your way, aren't your neighbours also your cousins? And/or sisters/wives/aunts, etc.
As an electronics design engineer, I'd say it's 100% the car, not the remote. If the central locking system is working as designed only the unique code from it's key fob, which changes with every key press, should open it. The fact it's key fob and another one open it, points to a fault in the car's ECU / central locking controller.
If my neighbour could open my car with his fob, I'd tell him and then get straight down the dealer. It's not my problem or my neighbours problem, it's the dealers problem but ultimately I'm the one at risk so I'm the one who will do something about it. I wouldn't expect my neighbour to do something about it. He's done nothing wrong whatsoever.
Plus, how many other remotes out there also unlock his car?
Some real nice people on here.... Yeah, just say **** him.... Probably the same people who complain they don't get on with their neighbours and escalate tiny arguments into neighbourly wars.
If you found out that say your front door key also opened your neighbours front door, would you -
A)Suggest your neighbours get a new lock, as it's clearly not secure.
B)Contact the people you bought the house from and ask them to sort you out a lock that doesn't unlock your neighbour's door?
http://www.briskoda.net/forums/topic/241468-my-key-fob-opens-closes-another-skoda/
What happens when you put your keys in the fruit bowl?
Is the OP sure that the carkeys were reunited with the owners properly after the last evening on which everyone threw their carkeys in the fruit bowl?
konabunny - Member
"What happens when you put your keys in the fruit bowl?"Is the OP sure that the carkeys were reunited with the owners properly after the last evening on which everyone threw their carkeys in the fruit bowl?
danger ahead!! 😆
hels - Member
My Anglia key used to open and start my mate's Escort panel van
lost the key to my Anglia and used the penknife on my key ring for a few months - remember being stopped by police for some non-naughtiness and sweating a bit in case spotted it and then being invited down the station
Sounds like a problem for the garage to sort out.
Although being me a spiteful little git, if it was my neighbour I'd not even bother with that as he's a nobber.
My cars secure, naaa naaa.
VW will do nothing about this as your vehicles security system is operating correctly, ie your neighbours keyfob does not open your car.
As footflaps says the issue is with the skoda central locking controller picking up your fob code and unlockingthe car which it shouldnt do. This is a relatively common fault with skodas and there are lots of complaints about this on the internet forums.
It is a shitty situation to be in with your neighbour but ultimately it is not you or your car that are at fault. I doubt this would be covered under the second hand car warranty anyway so if you decide to adapt your car to appease your neighbour it will cost you upward of a thousand pounds to change out all the central locking system.
Anyone who thinks that it's not the neighbours problem doesn't know how the security system works.
Feel free to take a trip to VW and ask them. But they will tell you it's the neighbours problem and Skoda need to sort out his car.
The VW system is working.
The Skoda system isn't.
It's not about being "neighbourly" that's just the way it is. Being nice can't really change that.
Just think - how gutted would you be - having your car ripped o bits to fit new locks and controller reprogged- just to fin his car still opens!
First i'd actually go round to the neighbours with your keys and actually see if it is really your fob that opens his car.
He could actually be mistaken, or it may have been a one off.
First things first!
Fair point. 😆
I wouldn't be surprised if other VW key fobs also open your neighbours car.
Although I know it is a slight security risk but his car should re-lock itself within 30 seconds if a door/boot isn't opened.
Before either of you go to a dealer, it might be worth speaking to Volkswagen Customer Care (0800 0833 914 ). At least that way neither you or your neighbour will waste your time going to a dealer. Especially when they will probably want to charge for investigating.
Sit naked in his car.
I actually thought it was not the neighbours fault until I read this and saw the light.
Absolutely the neighbours problem.
Yep. Why is it your problem? His coding is a whore
You could have a whole heap of fun with that.
I'd see how many of the local cats I could get into his car, or maybe something more subtle like moving his seat as far forward as it can go.
It's a shame the last post was deleted.
I need a kettle PAT testing urgently in Bedford
Some weird comments on here.
If my car could be opened with a key that wasn't mine, I'd be getting the system checked and re-coded so that it couldn't, rather than pouting at the owner of said key. Even if, for the sake of argument, the key had an inherent fault that was sending the wrong codes (or even if the neighbour had some sort of magic door-opening universal remote) ultimately there's still something inherently insecure about my car's system that I'd want it sorting. What if the OP gets his key 'fixed', what then, how many other keys are there out there that also need fixing?
Those who are saying it's the neighbour's problem aren't being un-neighbourly, they're correct (if a little blunt perhaps).
I second fill it with cats.
As with hora - sit naked in his car. Best outcome for stw. Pictures or it never happened.
It is quite clearly his problem, the people claiming otherwise lack any logical thought. It has nothing to do with being a good neighbour. Your car remains secure while his is not. His car is obviously the one with the problem. I'm not saying **** HIM LET HIM BURN, I'm just pointing out that the problem lies with his car not yours.
"Not the sort of people I'd want as neighbours" Why don't you take his car to the VW/Skoda garage for him, now there's a good neighbour. If you wouldn't do that for a neighbour then you are scum, sub human scum.
