Muc-Off or Worx pre...
Muc-Off or Worx pressure washer
So my Muc-Off pressure washer has expired - 6 months out of warranty.
To be fair Muc-Off have said they'll give me a discount of a new unit.
Contemplating getting a Worx - assuming I need the 24 bar for bike duties?
Only thing is I have all the attachments for the Muc-Off one and I like the snowfoamy thing lol
Advantage of Worx is can use it without a hose & power, but I also have a Mobi one for in the car/trailside duties.
So stick with Muc-Off or go with Worx?
Posted : 04/02/2024 7:35 pm
I've both...the word is the low power version (and is battery operated, so may not be what you are after anyway).
Worx is used more often - less faff, but both do a good job, however, it is still quicker at house to just turn the tap and use the attached hose.
I've used the worx at a trail centre and it works, but again, found it more often a faff than washing bike at home.
Aware this is helping at all...
Actually saying all that, I slid down the garden path this afternoon so the muc-off one will be used to jetwash the slabs and clean off the winter mank...the worx one isn't any good for that as it has less pressure.
Posted : 04/02/2024 7:41 pm
I have a worx and a nilfisk. If you have any use for the washer apart from bikes I'd say get another mucoff, especially as you have the mobi. I have a proper snowfoam attachment for my worx and it just doesn't have the oomph to do proper foam. As for patios and the like, forget it!
Posted : 04/02/2024 7:42 pm
got a worx for work, very robust and works despite extreme filth and neglect. Its an older model, original battery died so bought a new 5a? I think, tremendous kit. It's not powerful enough to clean a car, I believe newer brushless are more powerful though, if that's your bag
Would recommend
Posted : 04/02/2024 7:44 pm
My cheap Amazon hand held jet wash has still
failed to burn the house down 😃 Despite the warning on here.
Posted : 04/02/2024 7:56 pm
Thanks all - will go with the Muc-Off for home duties and keep the Mobi for trailside 👍
Posted : 05/02/2024 8:57 am
If only makita did one that I could use my existing batteries with!
Posted : 05/02/2024 9:55 am
Battery adaptors, I used my Bosch batteries with the Worx jetwash.
Posted : 05/02/2024 2:05 pm
Who knew?ย
Posted : 05/02/2024 10:48 pm
Got a Worx I've used on the trail side due to living in a flat and jerry can for water. Always worked really well. Also used for car washing duties when we had a hosepipe ban and then when my exterior tap failed.
Posted : 06/02/2024 6:03 pm
