Hi all
I a creating a query the gets an [entered date] - 7 days then - 14 days then - 21 days etc...
i have this
[code]
FORMAT(Appointments.[18 Week Start Date], "DD-7/MM/YYYY")
FORMAT(Appointments.[18 Week Start Date], "DD-14/MM/YYYY")
FORMAT(Appointments.[18 Week Start Date], "DD-21/MM/YYYY")
[/code]
The problem is that when i get to 14 and 21 the amounts are the same ๐
Please help
Cheers,
Neil
been a while since I did any work with Access, but wouldn't it be better to call dateadd() ?
http://www.techonthenet.com/access/functions/date/dateadd.php
Can't remember if it purely a VBA function or if they implement it as part of their SQL processing. If it is a callback to the VBA function the SQL query might run a tad slowly...(each row will have to be fetched then processed client side)
A fellow NHS worker no doubt?
try:
[code]
FORMAT(Appointments.[18 Week Start Date]-7, "DD/MM/YYYY")
FORMAT(Appointments.[18 Week Start Date]-14, "DD/MM/YYYY")
FORMAT(Appointments.[18 Week Start Date]-21, "DD/MM/YYYY")
[/code]
As long as the Appointments.[18 Week Start Date] is a date field you should be sorted
