Mouse in the house!...
[Closed] Mouse in the house!!!
 kilo
Mrs has seen a lone mouse in the kitchen and wants shot off it, do I place traps, and if so any recommended ones, myself or get a pest control bod in. House is newish, clean, etc. Any advice great fully received.
Posted : 11/09/2014 9:30 am
Little Nipper loaded with peanut butter
Posted : 11/09/2014 9:31 am
One of these:
[url= https://farm6.staticflickr.com/5583/14943441970_bf8f29e76d_c.jp g" target="_blank">https://farm6.staticflickr.com/5583/14943441970_bf8f29e76d_c.jp g"/> [/img][/url][url= https://flic.kr/p/oLv3Fd ]IMG_2052[/url] by [url= https://www.flickr.com/people/96650282@N08/ ]danbury collins[/url], on Flickr
Posted : 11/09/2014 9:37 am
First thing you need to do is establish if it is just one or two mice you are dealing with or more. Check all of the cupboards. It is most likely that there are some nice gaps around the pipework where it comes into the base of the cupboards which are providing nice access points. Wire wool and/ or expanding foam can sort them out. Also check the loft, the little buggers can climb well and you never know if they have had a chance to migrate upwards. Check for chinks of daylight around the roof edge from inside the loft. Also check things like air bricks and drain covers around the outside of the property. If the airbricks have biggish holes in them use fine steel mesh to cover the front of them.
Traps can work, peanut butter is as good as any as a bait. Chocolate spread works well too. You are best to use multiple traps for mice. Little nippers work well, in fact most of the mouse ones do. If you decide to get a pest control bod in he will most likely want to use mutiple bait points. A sound approach that takes advantage of the mouses feeding patterns. Expect to pay between £80 - £100 for up to three visits. Any more than that and any fewer visits and you are getting ripped off.
Posted : 11/09/2014 9:48 am
Do what my wife did and waft it away.
We saw a mouse in the kitchen which ran behind a movable unit. When I moved the unit the mouse ran back the way it came and my wife grabbed the first thing that she could get hold of (a piece of junk mail) and tried to smash the little blighter with it. The force applied to the mouse was just about enough to flatten it's back hair.
I couldn't move for laughing.
Mind you it hasn't been back, and we have three little snappers hidden around the kitchen.
Wafting is the way to go.
Posted : 11/09/2014 9:50 am
peppermint oil on cotton buds under the kitchen cupboards seems to have worked for me
Posted : 11/09/2014 10:09 am
This. There will be more though. Make sure there is absolutely no food available, crumbs, cat/dog food etc too.
Big Dave's advice is spot on too. We had them in the loft. I poisoned them in the end, as I just kept catching them in the traps.
Posted : 11/09/2014 10:14 am
"[i][b]Mice [/b][/i]in the house"
FTFY, assuming you don't have a cat that likes to bring you gifts
Posted : 11/09/2014 11:12 am
Tip Traps work very well if you don't fancy killing them (or don't want a half dead mouse crawling somewhere inaccessible to rot).
Main thing though is to reduce available food sources (i.e put all your cereals in plastic boxes etc) and plug up any holes and entry points using gap filler and wire wool. If you don't do this you'll just get more mice in the future.
Posted : 11/09/2014 12:14 pm
If you have small kids ,Tip traps are ace .
Used to catch them ,then let them run around in the bath( the mice,not the kids) 🙂
Chocolate raisins were the best bait.
Posted : 11/09/2014 12:25 pm
Kill 'em, unless you want a live mouse in a box.
Posted : 11/09/2014 12:26 pm
Aw Cougar,it was a lot of fun letting them go in the school playground (the mice ,not the kids).
Posted : 11/09/2014 12:28 pm
Where there's one, there' always more than one.
I've spent a fair bit of time in Malawi over the past 4 years and this is how they deal with them there... basically a nice bar snack.
Posted : 11/09/2014 12:36 pm
You can also get electric mouse traps which will kill more than one mouse on a single set of batteries. Not had a chance to use one yet but I believe they are quite effective. They would at least remove the risk of having to deal with a half dead mouse dragging a trap around behind it.
Posted : 11/09/2014 12:38 pm
The answer is to tie a bit of string to the staple on the little nipper and tie it to something so the little *******s can't get far.
When it comes to the house the only good mouse is a dead mouse
Posted : 11/09/2014 12:43 pm
Call me an old hippy, but I'm just not a big believer in killing things just because they are mildly inconvenient. We even catch and release spiders and insects in our house. 😀
(Besides I wouldn't want snap traps about where the kids are).
OP: no one has mentioned sonic plugs yet. They are worth sticking in, but only in addition to the other defensive measures. Some mice will brave running past them, so put them in places where there is food or they might stop to hide (e.g. pantry, behind the sofa etc)
Posted : 11/09/2014 12:54 pm
We had a bit of a maouse problem in our attic last year.... could hear them at night.
Tried normal "snap traps" - the mouses seemed to just remove the bait.
tried humane "tilt traps" and found a mouse dragging it across the attic floor...
so I resulted to a Bucket half full of water, length of wood for the mouse to crawl up - baited with little blobs of chocolate spread, coke bottle (both ends removed) taped underneath half way up on the end (to make a see-saw type tube....
Blob of chocolate spread on the far end of the "Tunnel"
Mr mouse walks up wood... walks into tunnel... tunnel "over balances, and tips mouse into water - mouse gone.
I got 9 mice like this in 2 nights (multiple buckets)
[URL= http://img.photobucket.com/albums/v73/adi-66/facebook/381153_10150417221536402_307258700_n_zps3cc0cf15.jp g" target="_blank">http://img.photobucket.com/albums/v73/adi-66/facebook/381153_10150417221536402_307258700_n_zps3cc0cf15.jp g"/> [/IMG][/URL]
...they've not been back since.
Posted : 11/09/2014 12:56 pm
Kill 'em,
But kill them with kindness - look, made with natural whole wheat. Its good for them
Unlike 'Pasta Bait' (ooer) which not only is full of empty carbs, but also probably makes them go blind or get hair palms or something
Posted : 11/09/2014 1:00 pm
I found the best way was to *carefully* half-trip the trap, pushing the floor down so that it's right on the edge of almost firing. I had a couple of baby mice that were too small to trip the trap, preloading it like this made it catch the buggers.
As a card-carrying yoghurt-knitting vegetarian nor am I, but, mice breed like bastards and are incontinent. I don't like killing things, but I like my floor covered in mouse excretions even less.
Posted : 11/09/2014 1:01 pm
See I've got two young kids so my floor is constantly covered in assorted human excretions anyway 😀
Posted : 11/09/2014 1:06 pm
Little Nipper loaded with peanut butter +1
Posted : 11/09/2014 3:23 pm
Little Nipper loaded with peanut butter +2 - took less than one hour from putting it out to catching the little blighter when we had one the other week, approximately one week faster than the "humane" alternative that had been out!
Posted : 11/09/2014 3:26 pm
maccruiskeen - Member
What if it's on a gluten free diet? You total ****.
Posted : 11/09/2014 3:41 pm
Great sport with an air pistol. Just sit in the kitchen at night with a few beers and wait to see what happens.
Posted : 11/09/2014 5:38 pm
We have two of the electronic mouse Zappers - both charged and baited at all times. I've lost count, but the original one must be up to at least 40 'kills'. I should have marked them off on the trap like a fighter pilot from WW2
Marko
Posted : 11/09/2014 6:01 pm
They'll get over it - most people's wheat intolerance seems to wear off once they get bored of it. 🙂
Posted : 11/09/2014 6:31 pm
