Mould on shower gro...
[Closed] Mould on shower grout - how to remove?
Our shower grouting's looking a bit ropey, with bits of black mould around the junctions nearer the base of the shower. What's the best way to get rid of it?
Or should I just smear new grouting over the top?
Or get rid of the old, and put in new? - won't the tiles fall off?
Posted : 01/10/2010 10:44 am
tiles are glued on, scrape some out an re apply. its dead easy
Posted : 01/10/2010 10:46 am
If it's really bad it might need replacing, but you can try scrubbing it with a toothbrush dipped in bleach.
Remember not to use the toothbrush for teeth brushing afterwards...
 LHS
Some cream cleaner and a toothbrush, for hard to remove - brillo pad or similar, ensuring no damage to tiles.
In ours it wasn't the grout that was mouldy, it was the silicon sealant. Take another look, if it the same in you case, cleaning/chopping it out is the only solution, the replace withmould resistant stuff
Posted : 01/10/2010 10:47 am
Aqua panel.
Wot zippy said, more likely the sealant if it's at the bottom
Posted : 01/10/2010 10:48 am
You can get bathroom cleaner with bleach which is pretty good.
Failing that you can get grout reviver that deals with really bad cases.
Posted : 01/10/2010 10:53 am
My mother in law did it for us.
๐Ÿ˜€
Posted : 01/10/2010 10:57 am
bog standard bleach works everytime, none of this scrubbing bollox
Yeah, the thing with the bathroom cleaner is that it is foamy and sticks for longer so you can just spray it and leave it there for 15 minutes.
Saying that, I have never tried simple bleach.
Posted : 01/10/2010 11:05 am
Yep, plenty of bleach (the thick type) and a nail brush, stiff toothbrush, or (white) pan scourer.
Apply bleach, leave for ten mins, scrub, leave, rinse.
Keep the door/window open to avoid choking on fumes.
Get naked to avoid bleach spots on your best top.
Posted : 01/10/2010 11:51 am
empty a spray bottle, fill it half with thick bleach and then add about a 1/4 water (leaving a 1/4 of the space in the bottle left) shake it up to make it slightly foamy and then spray all over the bathroom..... leave it to drip slowly down the tiles and then if you're feeling like a second spray... go for it, no one will judge you (unless you're wearing a full-face and body armour.. not getting the point of it all)
much cheaper than re-tiling or grouting 8)
Posted : 01/10/2010 12:06 pm
If it really is the grout and not just surface muck then a bit of sand paper folded in 2 and run down the joint will remove a bit of grout and clean it up, don't do it often though as obviously you're removing a layer of grout everytime.
If it is right into the grout then raking out and regrouting is the only way as the mold lives on the trace elements of starch in the grout and will be present right through it. Same for silicone, if right through as opposed to a bit on the surface, knife it out, clean it up then apply new sanitary grade silicone to DRY (very important) surfaces.
Don't over grout or over silicone, you're wasting your time and money.
Posted : 01/10/2010 12:18 pm
put bleach on it and leave it for a few hours, then get a brush and scrub it off
I think I'm turning into a housewife
Posted : 01/10/2010 12:23 pm
Simplest way is to soak kitchen roll/toilet paper in bleach, scrunch and stick to grouting. Leave overnight, take off and rinse.
Posted : 01/10/2010 12:25 pm
Get some of this:
Posted : 01/10/2010 12:29 pm
Was just about to post the above. Dettol mould and mildew is the best stuff. If that won't shift it, nothing else will and it's new grout time.
Be careful with bleach, i've seen it turn grout and silicone yellow.
If it is your silicone, chances are it won't come clean.
Replace with mapei silicone. It will still in mouldy eventually but will outlast anything else
Posted : 01/10/2010 12:39 pm
Do not, under any circumstances, let anyone talk you into digging out & replacing the grout.
It took me 3 days for what was sold to me by Mrs RBIT as a half day job (which, if I'd known, I would have paid someone else to do as it went over the back of the value of time x money curve), and one of my friends reckon that it brought him and his wife as close to divorce as they've ever got.
Andy
Posted : 01/10/2010 12:54 pm
second what matthewjb says, mrs boggy did our bathroom with that this week and it works a treat, much easier than messing with bleach etc, just spray on leave a few mins wipe with a cloth and rinse, simple as
Posted : 01/10/2010 5:29 pm
Yep, that Dettol stuff works a treat. Spray in on for about 5 minutes and then just rinse it off.
Posted : 01/10/2010 6:25 pm
what mathewjb said. That stuff kicks mouldy mildewy ass.
Posted : 01/10/2010 6:27 pm
The Dettol stuff is what our [s]cleaning lady[/s] domestic hygiene assistant recommends.
Posted : 01/10/2010 6:36 pm
THIS. JUST. WORKS.
Posted : 01/10/2010 6:43 pm
urine
Posted : 01/10/2010 8:14 pm
+1 for grot buster. Soak some cotton wool with it and place over the affected areas. Leave it overnight an et voila no more blackness.
Posted : 01/10/2010 8:55 pm
Did anyone mention the cheapest, easiest solution?
Bleach
Posted : 01/10/2010 9:50 pm
Silicone sealant - guaranteed not to cure the leak properly and to look mouldy. My least favourite product of all time.
Posted : 01/10/2010 10:49 pm
