Motorbike woes - EC...
[Closed] Motorbike woes - ECU died possibly?
 Aus
Thanks for the advice given last week. Saga continues.
I've a 2002 F650 Dakar, previously running perfectly. Over the cold spell, the battery started struggling so assumed it had done its time. I got a Mottobatt, fitted it, and it started perfectly. Next morning, went to start it and noticed when I turned the ignition on, I didn't get the coolant light coming on. It cranked over healthily but wouldn't fire.
So I've checked/looked at:
- all electrical plugs/connections to see if clean, attached
- by-passed the side-stand by 'shorting out' the connector plug
- the kill switch does seem to be working i.e. if I switch it off, it doesn't crank
- there's no immobiliser or ABS
- power is getting to the ECU
I've changed the starter relay
all fuses good
- I don't hear the fuel pump come on when I turn the ignition on, but direct power to the pump and it works fine
I borrowed a GS911diagnostic computer checker thingy and it was 'unable to connect to the ecu - please check ignition is on/immobiliser is off/kill switch is off/side stand up'.
Now I'm not a mechanic so struggling as to what to look at now. I've taken the casing off the ecu and the circuit board looks OK i.e. no obvious shorts; little bit of corrosion around pins 28/27/9 but fairly slight.
I'm guessing that the ECU is not activating when ignition turned on ... ? But gather it's very unlikely for them to fail.
Any suggestions - am pulling my hair out!
Thanks
Posted : 12/02/2017 12:28 pm
I've never heard of an ECU failing on an F650.
Have you tried the universal reset? Disconnect battery (both sides) and leave it for a few minutes, before reconnecting and trying again?
Failing that, a post on UKGSer.co.uk might reveal an answer...
Posted : 12/02/2017 12:59 pm
regulator ?
That's what it was on an old ZX9 and my 998s
Posted : 12/02/2017 1:16 pm
The fact that it ran with the new battery on but then not the following day points towards charging issues. The battery may not be charging or you have a short draining it down.
Try charging the battery and see if you can get it to fire up again.
Posted : 12/02/2017 2:36 pm
 Aus
Thanks.
Ive removed the ECU and opened it up and left overnight in the house to remove any damp that may have been there. No obvious burnt out elements that I can see.
I'll look at the regulator but would imagine that with a fully charged battery, it would at least fire up?
Posted : 12/02/2017 3:30 pm
 br
Side-stand cut-out issue?
Posted : 12/02/2017 4:35 pm
 Aus
I've shorted out the side-stand (I think/hope) to rule it out.
Posted : 12/02/2017 5:41 pm
