MotionX GPS Users (...
[Closed] MotionX GPS Users (GrahamS) - help needed
I downloaded the app for iPhone and then created a route on CycleStreets (the website; tried Chrome and Safari). I then downloaded this route as a .gpx file which I emailed to the address given by the MotionX app. It duly arrived back with the link which opens the app and is supposed to download as a track. Each time I tried (3 or 4 times IIRC) the app said there was no readable data in the .gpx files. Am I doing something wrong? Should I create the track with another website other than CycleStreets? Both the website and the app seem to use the same maps ๐Ÿ˜•
(GrahamS, if you're reading, I downloaded the app after you mentioned it on another thread regarding Cyclemeter and other apps wrt data usage. And of course you're a techie ๐Ÿ˜€ )
Posted : 20/04/2011 9:55 am
Open the .gpx file you originally downloaded from CycleStreets in Text edit and check that there is stuff there would be a good starting point.
If there isn't, try again, or try creating one in where's the path http://wtp2.appspot.com/wheresthepath.htm
Posted : 20/04/2011 9:58 am
Here! ๐Ÿ™‚
Hmm.. I've only tried downloading from MotionX not uploading to it.
Give me a minute and I'll have a play...
Posted : 20/04/2011 10:18 am
Hmm same thing here:
Import Finished: 1 item was read but didn't contain any usable data.
I'll investigate.
Posted : 20/04/2011 10:27 am
Right - it doesn't look like they are compatible (I think)
MotionX deals with [b]tracks[/b] (trk) which are just a collection of points (trkpt) every few seconds like this:
[code]<trk>
<name>Wylam wood Road</name>
<desc>16 Apr 2011 12:26 pm</desc>
<trkseg>
<trkpt lon="-1.829131" lat="54.971664">
<ele>8.371592</ele>
<time>2011-04-16T11:26:38Z</time>
</trkpt>
<ele>12.166491</ele>
<time>2011-04-16T11:26:54Z</time>
</trkpt>
...[/code]
Whereas Cycle Streets produces a [b]route[/b] (rte) which is basically a series of waypoints (rtept) like this:
[code]<rte>
<name>Balanced Algernon Terrace to Sunderland Road</name>
<desc>Balanced cycle journey from Algernon Terrace to Sunderland Road</desc>
<rtept lon="-1.823186" lat="54.977043">
<name>Cherry Tree Lane</name>
</rtept>
<rtept lon="-1.822657" lat="54.976395">
<name>Main Road</name>
</rtept>
<rtept lon="-1.820677" lat="54.976482">
</rtept>
<rtept lon="-1.819329" lat="54.976158">
<name>Falcon Terrace</name>
</rtept>
[/code]
The good news is that there is also a Cycle Streets phone app so you could maybe try using that?
Posted : 20/04/2011 10:40 am
Alternatively you can [url= http://www.gpsies.com/convert.do ]use the GPX Converter at GPSies.com to convert[/url] the Cycle Streets route file to a MotionX-compatible track file.
Failing that, CycleStreets is still in beta and has a feedback form, drop them a line, tell them of your difficulties and let them knwo you'd like to be able to download your route as a track.
Posted : 20/04/2011 11:01 am
