MOT this evening......
[Closed] MOT this evening... what will my car fail on?
skoda fabia, X reg, 1.9 sdi, 61k on the clock, new tyres last week, bulbs replaced last week, windscreen wipers replaced yesterday and new windscreen fitted after a crack developed last week.
so i've already spent a fair amount on it in the past 2 weeks so i'm fully expecting it to fail on something expensive 🙁
skoda fabias from before 2005 have an issue with the power steering sensor so at any point in a journey the power steering can fail but this is fixed by starting the engine again 😆 i'm putting money on the power steering light coming on 30seconds into the MOT test.
long weekend of driving planned so its gotta fail hasn't it?
Posted : 23/11/2012 10:25 am
One of the new tyres will get an irreperable puncture on the way to the test station.
Posted : 23/11/2012 10:26 am
With an attitude like that, then yes.
is this a sweepstake?
X Reg, hmmmmmm a coroded brake pipe or a CV joint boot
puncture.... most likely 😆
sweepstake, if you win then you get to donate £5 to charity 😉
Posted : 23/11/2012 10:27 am
Rear numberplate light.
Posted : 23/11/2012 10:30 am
I was just about to post the very same thing. I'm going to narrow my selection then. CV Boot
Posted : 23/11/2012 10:33 am
I'm going for handbrake cable.
Posted : 23/11/2012 10:36 am
Always cv boots and brake pipes
Posted : 23/11/2012 10:37 am
shouldn't have started this thread, now i'm adding up the list in my head of things it could fail on! 😯
Posted : 23/11/2012 10:38 am
 sbob
I was going to go CV boot, but as that's been taken I'll go for premature piston ring failure leading to failure of emissions, which won't be diagnosed until four figures worth of diagnostics.
Good luck!
Posted : 23/11/2012 10:40 am
has it had any previous cutlery based repairs?
Posted : 23/11/2012 10:42 am
cutlery?
Posted : 23/11/2012 10:43 am
just seeing if cynic-Al had been involved in maintenace. Someone up there had posted 'Al' as the reason for failure.
Although they've changed it now 🙁
Posted : 23/11/2012 10:45 am
ahhhh i seeee. no cutlery repairs 😀
Posted : 23/11/2012 10:47 am
Some obscure, dealer-only suspension part...
Posted : 23/11/2012 10:50 am
Shock absorbers.
Posted : 23/11/2012 10:55 am
Empty water bottle or badly adjusted washer jets.
Huge crack across the screen on the way to the test.
Posted : 23/11/2012 11:01 am
A friend of mine wrote his car off with the restaurants worth of cuttlery in the back of his estate. He was waist deep in knifes and forks while the fire brigade were cutting him out 🙂
Posted : 23/11/2012 11:05 am
Emissions or lower arm
Posted : 23/11/2012 11:15 am
 br
Bulbs, and headlamp alignment.
Posted : 23/11/2012 11:18 am
ohhh headlight alignment could very well be a winning bet
Posted : 23/11/2012 11:21 am
Increase your chances a whole heap by cancelling your MOT and taking it to a 'just mots' place. Unless you have already 🙂
P.S Rear numberplate lights usually catch me out. Had a close call with a worn rubber on the brake pedal as well, turned it 180 degrees and it passed with no advisories the next year 🙂
Posted : 23/11/2012 11:40 am
I'll go for rear handbrake at fill pull and right rear wheel bearing knackered.
Posted : 23/11/2012 11:46 am
I was going to plumb for handbrake adjustment but that has already been taken.
So along the same lines rear brakes binding.
Which charity is the donation to be sent to?
Posted : 23/11/2012 11:58 am
 momo
Ooh I'll play, track rod end ball joint!
Posted : 23/11/2012 12:00 pm
front nearside wishbone bushes, and rear drop link or arb bush
Posted : 23/11/2012 12:01 pm
Another one I suffered,
One head light bulb was 'multi-coloured', the other white. Either is fine, but they both have to be the same. You had to stare into the beam to tell the difference!
Posted : 23/11/2012 12:03 pm
I am currently winding up my work colleague, his car is in today too.
It's a game we play to make the days pass quicker - what japes.
He is sitting nervously by his phone , fearing the dreaded call...FAIL.
O.P. - front suspension boot.
Posted : 23/11/2012 12:04 pm
had my x reg fabia mot'd last week - cost me £500 all in all 🙁 ....included both bushes and a cracked spring. 61K mileage is good for x reg tho! mines up to 110K.
Posted : 23/11/2012 12:24 pm
rear numberplate lamp, mil lamp or abs light on
Posted : 23/11/2012 12:25 pm
X reg Fabia 1.4 16v 81k - MOT on Tuesday - passed - advisory for corroded exhaust.
MOT Prep - one number plate bulb , one sidelight bulb. Oil change .
It is a silver car, or was on the previous MOT , now it is grey - must wash it..
Posted : 23/11/2012 1:33 pm
I have an R Reg Skoda Felicia 1.9 diesel. It has failed the last two MOTs on CV joint gators, and a top shock mount. Advisory on a perished exhaust mount, and play in the steering rack.
Posted : 23/11/2012 1:44 pm
Worn rubber on the brake spooky? My landy has no rubber on any pedals
Ill take arb bushes
Mine went though recently with an advisory for drift shaft seal on gear box ( it was hosing oil and was just an advisory !!!!!) told them to get it fixed
And an advisory for rear brake imbalance - within tollerance apparently but close to being out. - again get it fixed
Scary thing is - some folk would regard that a pass and get no further work done :/
480 quid all in inclusive with a service and cambelt and waterpump change
Posted : 23/11/2012 1:45 pm
Empty washer bottle
Posted : 23/11/2012 1:46 pm
t_r you got that landy on the road now????? or was it another motor?
Posted : 23/11/2012 1:50 pm
Rust only found when tester sticks his screwdriver through a sill or or something. Once got a bit vexed with a tester I knew hitting the chassis on my old Vito with a hammer, hitting it very very hard 😯
Posted : 23/11/2012 1:51 pm
Is MIL a fail?
Posted : 23/11/2012 1:53 pm
Have i hell russ
Im currently farting about with the insde of an lt85 gear box in my garage so i can get my v8 fitted factory looking
Mot was on the van.
No rubber on the landys never been an issue when i had it on the road 🙂
Posted : 23/11/2012 1:55 pm
Used to put spots of weld on the metal pedals on the old Land Rovers to get through MOTs 😀
Posted : 23/11/2012 2:36 pm
I took my old polo for an MOT years ago. I'd agreed to sell it to the friend and MOT it before I gave it to them. Went to pick it up
"everything OK with the Polo?"
"sort of"
then he reeled off a number of fails, and the things they had tried to do to rectify them, how that hadn't worked so finally they'd had to replace the fuel pump and some other bits.
They totted up a bill for about £600. I was thinking "christ, was there not a point when you might have picked up the phone"
As I started getting my checkbook out, the guy hands me some keys
"those aren't my keys"
"Oh the [i]red[/i] polo. That ones fine, passed first time"
Posted : 23/11/2012 2:38 pm
Blowing exhaust.
Posted : 23/11/2012 3:00 pm
wide range of guesses.... big list of things i'm now worried about!
61k.... i've put 40k of those miles on it in the past 2 years, bought it with 21k on the clock, service history and MOTs to back up the mileage, old guy had kept it in a garage for years and only ever driven to the shops once a week, even paid for a skoda tech to come to his house for a yearly service 🙂
i however haven't treated it so well!
Posted : 23/11/2012 3:06 pm
Number Plate Light
Loose wing mirror glass (mine actually failed on that the other day, you'll be pleased to hear).
Posted : 23/11/2012 3:08 pm
careful how you pick it up, it'll be hot!
Posted : 23/11/2012 3:10 pm
 Sui
Well, hows about you take said car for MOT it passes with an advisory on the drive shaft - then 200 meters down the road said drive shaft pulls itself out of the joint with no warning... 👿
Posted : 23/11/2012 3:12 pm
perished tyre material is my guess.
Posted : 23/11/2012 3:13 pm
Posted : 23/11/2012 3:21 pm
it'll be hot!
No it ****in' won't 🙁 Broken.
New one arrived on Friday though. 😀
Posted : 23/11/2012 3:22 pm
[i]Worn rubber on the brake spooky?[/i]
I think it actually went down as something along the lines of 'brake pedal anti-slip provision worn' or something to that effect. You could just see through to the metal on one corner, so spun it round so there is now fresh rubber on the edge.
Maybe its one of those things that can't fail if it isn't present...like my missing bump stops. One fell off, so I was forced to remove the other so it wouldn't be failed. Took ages to get it off but the ride is much better now 🙂
Posted : 23/11/2012 5:08 pm
 br
I had a problem yesterday with my car, felt like a seized O/S front caliper. So whipped the wheel off and one of the pads had lost its retaining spring, plus well worn along with a well corroded/gouged disc. Nothing wrong with the caliper.
Got new discs and pads, O/S went on no probs. Took N/S wheel off, and again a well worn pad and a seized caliper... Bu99er. And can't get one until Monday. Double bu99er.
Any ideas though for how to get a seized brake hose nut undone?
Posted : 23/11/2012 5:36 pm
21k in 2 years driving to the shops once a week, where did he live Alaska?
Posted : 23/11/2012 5:45 pm
he did 21k in about 10 years, i've only owned it 2 years.
passed the MOT 😀
i'll donate a tenner to macmillan cancer support though 🙂
Posted : 23/11/2012 6:55 pm
