More monitor woes -...
[Closed] More monitor woes - what connection
My new 28" Benq monitor arrived with HDMI connection. Unfortunately the laptop I thought had HDMI has what is shown in the phot below instead. Whats that?
Fortunately on the back of the monitor there is another hole the same shape so I am guessing I just need to buy the right cable which isn't HDMI.
What is it please?
Posted : 29/05/2020 4:37 pm
It's a "Display Port".
Cables are pretty cheap and I think it is generally considered to be better than HDMI.
Posted : 29/05/2020 4:38 pm
HP have given up and now moved to HDMI. My new laptop has hdmi but the old docking station uses display port. I bought a small adaptor.
Posted : 29/05/2020 4:45 pm
Just bought three adaptors for the three machines
VGA - HDMI
DVI - HDMI
DisplayPort - HDMI
You have got to love industry standards!
Posted : 29/05/2020 4:48 pm
There are two or three sizes of displayport. You may also be able to get a USB-C dock that you can plug the monitor and everything else into, but you need to check what the USB-C port on your laptop supports, as some do displayport through the USB-C, some don't. Some also do power through the port, others don't.
Posted : 29/05/2020 4:50 pm
Well the Universal Serial Bus connection has I think 8 different connection types so can be described as many things but I'm not convinced that "universal" is one of them.
Posted : 29/05/2020 5:12 pm
I actuallyjust bought a display port to display port cable as I was using the other two HDMI slots for the other two computers. Didn't notice anything about different sizes so lets hope I randomly hit the right choice
Posted : 29/05/2020 5:30 pm
Bit odd with a laptop using display port. I work at a Uni, and all meeting rooms etc have large TV's so HDMI is the most common. Lots of desktops use Display port, and I personally like it better as the cables click in. I have display port to HDMI for the media pc under the TV in the house, but Display port to DVI for the Zwift setup in the garage - monitors are DVI. Mind boggles.
Posted : 29/05/2020 7:12 pm
I think HP went big on the display port thing. All our old laptops at work have them, were a pain wje visiting a client's office and they just had an HDMI cable for the meeting room TV. New ones (not HP) don't have them.
Posted : 29/05/2020 7:59 pm
Yes. Display port. Cables are easy to come by on your usual on line sources. And as has been said, they’re less liable to work loose than HDMI. Otherwise they’re just another connector.
I got a Benq last year. I didn’t stretch to the 29” one with USB-C in as well as whatever others. Instead got one with HDMI, display port, and mini display port if I remember correctly. I’d been using HDMI to HDMI with one laptop and USB-C to display port with my Mac. Then I discovered that what I though was a Kensington lock hole on the PC was a USB-C port. Unexpected. Now it’s USB-C to MDP all the way.
Posted : 30/05/2020 6:27 am
There is also a display port mini. One of my monitors goes through two media converters (display port to HDMI and then HDMI to display port mini) to go from display port at the GPU to display port mini at the monitor. Don't ask why, I think it was just what I had lying around. In the past, I've had problems with media converters, something to do with sufficient power.
Posted : 30/05/2020 11:19 am
I have a couple of spare display port to hdmi cables (which to my cost I have found out are not hdmi to display port... go on ask me how I know... 🤔🙄).
My monitor (Lenovo) came with a display port cable. My laptop (Lenovo) has hdmi. I solved my problem by actually checking the monitor and finding it has three connectors and went hdmi...
Posted : 30/05/2020 11:26 am
