Has anyone ever exported data from a Microsoft SQL db into a postgres db.
Some of the tables contain spatial data.
So far I've tried these commercial products:
DbConvert (trial) - crashes straight away
DbSync (trial) sort of works but crashes with out of memory error on one table
SpectralCore FullConvert (trial) - crashed
I have no idea what to do with pgloader (or how to even install it on windows)
You can get SQL server to write out a load of insert statements for all the data in specific tables. If your data structures closely matches in postgree then you could probably run it in with a few tweaks. Other option is an SSIS package, assuming postgree has an ODBC driver that SQL management studio can access.
last place i worked used Postgres as a datasource for the TSQL data warehouse and using open query allowed the transfer of data out. I don't know how the linked server was set up. Wasn't my job and never went wrong so never had to learn. So definitely possible that way. i guess the other way is also possible
The messy way would be export to CSV table by table and reconstruct, but i assume you don't want to do that?
Yes, have done both from Oracle and sql server into postgres.
Not always straightforward.
These days I'd go straight to fme to do this but prob not something you have available
Dbvisualizer will write out dml statements for a database, but it's not a free tool. There is an evaluation period though. You could then manipulate the sql statements as necessary for import to postgress.
Presume you've got the PostGIS extender for Postgres to handle spatial data?
As above, FME will help and you can get a handy 30 day trial version.
Have a look at Talend
