I'm trying to design an impact force device for Yr 7 pupils in the school I work in. I have loads of micro bits.
My code is designed to record an impact >3G and then display this on the LED array of the microbit. I can't do javascript but can give the block editor a good try. Converted to javascript my code looks like this:
input.onGesture(Gesture.ThreeG, function () {
basic.showNumber(input.acceleration(Dimension.Strength))
In other words, at a 3G impact the size of the impact is displayed.
BUT... the display scrolls the result through once and once only, so the pupils will not really get much of a chance of seeing/ recording the value if the object rolls away/ lands in an odd position. What I need is a way to keep the impact value scrolling around repeatedly. Any suggestions?
You probably want it in some sort of loop, or at least to add a delay. You could manually do that in Javascript or using the block editor. JS is not my day-to-day but micro:bit supports python. I don't have one to try... but can probably get you 1/2 way there. i'll go look at the documentation...
Thanks poly. I thought about a loop but I'm out of my comfort zone.
Here is a crude suggested approaches:
from microbit import *
while True:
gesture = accelerometer.current_gesture()
if gesture == "3g":
display.show(accelerometer.get_z())
sleep(1000) # will wait 1s (1000ms) before moving on
else:
display.show("-")
Note I've assumed you wanted the vertical (z axis) acceleration displayed (swap z for x or y as appropriate - if you don't care you could use:
display.show(max(accelerometer.get_x(),accelerometer.get_y(),accelerometer.get_z()))
and it will show the biggest in any of three directions.
An alternative would be something like:
while True:
if gesture == "3g":
value = max(accelerometer.get_values())
display.show(value)
elif gesture == "shake":
display.show("-")
Which I *think* should display - then when it gets a 3g geture display the largest accelerometer value and leave it on the display until you shake the device to reset it.
Oh you star, I'll give it a go in the morning ๐
https://makecode.microbit.org/reference/basic/show-number
that help?
or, what poly did whilst is was looking up the syntax. Pffft
@Ambrose I've edited the shake bit - because what I wrote was dodgy! I also found a "get values" which gives x, y and z with one command.
Have fun.
If you really want to do it in javascript or the block editor then jim's link will let you translate what I wrote in python (that may be useful if I have any syntax errors there!).
while True: is the equivalent of the "forever" block
sleep is the equivalent of pause block
Also - i've used "show" - if its more than 1 character you probably want "scroll". I'm not sure if it scrolls the same thing continuously until stopped or it scrolls it once. if the latter - you'll need to wrap the scroll in another loop to keep it doing that. Potentially that might be something like:
while True:
if gesture == "3g":
while accelerometer.current_gesture() != "shake":
display.scroll(value)
sleep(100) # 0.1s pause to make the end more obvious
Cheers Both. I'll admit to getting lazy on this, I just gave the challenge to one of my Yr 10 pupils.
He came up with this:
let _1 = false
let number = 0
input.onButtonPressed(Button.A, function () {
_1 = true
input.onButtonPressed(Button.B, function () {
basic.showString("" + number)
if (_1 == true) {
number = input.acceleration(Dimension.Strength)
basic.pause(100)
_1 = false
It works, I'm happy. So is he- he got a load of praise and appreciation.
