Metalworkers... can you make me a thingummy?
One of these days I'll write something about mountain biking.
Anyway...
ย
I need some new gate hinges and rather than look around for local metal places I thought I might try here first, would rather pay someone from STW 🙂
Would anyone be able to make four of these? It's just a bit of threaded rod welded onto the side of a tube.
ย
Dimensions:
Internal diameter 17mm, external 22mm (wall thickness 2.5)
Length of tube 30mm
Rod is M12 thread, 105mm long
ย
Any reason it needs to be custom made? You can buy them for a few pounds. Search for adjustable gate eye bolt
You can get them mail order from FH Brundles
I would make some for you if i was at work, butย retired now, and have no tubing to fit here
As nickjb says - just buy some gate eyes. If you're really stuck and they have to be custom made, or modified then drop me a message - I can sort it. But they may be the most expensive gate eyes ever made! 🤣ย
Huh. Fancy that. I couldn't find anything like it. Well that's a Google fail 🤣
Thank you all!
ย
Toolstation do them.
Judging by the state of the one in the photo, liberal quantities of grease should be applied regularly, too.ย
