Mac users - delete ...
[Closed] Mac users - delete just jpegs in folders
Hi all,
Running out of space on my mac, so trying to clear it out a bit. I have jpeg and raw copies of a lot of pictures, so want to delete all the jpegs. Is there an easy way to select just the jpegs in Finder - they are currently alternating jpeg and raw? Sorting by image size or type doesn't do anything.
Thanks,
Duane.
Posted : 06/09/2015 11:05 am
 IA
Do a search and delete them from there.
Or in terminal:
would delete any files ending .jpg in that folder. They'll be gone with no warning or recycle bin tho, so be careful!
Posted : 06/09/2015 11:09 am
 IA
Oh and by search i mean type:
"kind:jpeg"
in the search box of finder, that'll find any jpegs with whatever extension. Should be obvious how to choose current folder (rather than the whole mac!)
Posted : 06/09/2015 11:10 am
Thanks. Searching a folder is good, but it also comes up with any jpegs in a folder within that folder - so risk deleting those by accident if I'm not careful.
Posted : 06/09/2015 11:14 am
 IA
Oh, and "disk inventory X" is a good app to see where all your space has gone.
I'd have though sorting by size would make this easy?
If that doesn't work, then this may be a job for the terminal...
Something like
find /path-of-folder -name "*.jpg"
will list all of the jpegs in a folder (And folders below that).
If you are confident that all of these files can be removed then
[b]
*DISCLAIMER - This bit will remove files!!! DO NOT DO THIS UNLESS YOU ARE SURE!
[/b]
find /path-of-folder -name "*.jpg" -delete
Will delete them as well.
If you don't want to search recursively then please ignore my advice above.
You can do
to list all jpegs, and as IA says above,
to remove them
 IA
Ok if you want just in a folder, the best way I know is the command line. Be careful though (or update your backups first!):
In terminal, you change folder with "cd", list files with "ls" and delete with "rm" and it'll match patterns. So "rm *.jpg" removes any file ending with .jpg.
E.g.:
Macaroni:~ iain$ cd Pictures/
Macaroni:Pictures iain$ ls
Aperture Library.aplibrary LightroomMasters
Desktop Photos Photo Booth
DoubleTake Library Photo Booth Library
Flowers.jpg iChat Icons
Google Photos Backup in-unsorted
Lightroom
Lightroom
Macaroni:Pictures iain$ ls *.jpg
Posted : 06/09/2015 11:17 am
Am I doing something wrong if when I select the "Item Arrangment" box for a folder and choose sort by Name, it doesn't sort by name - ie the list could still be:
P10209
G898
P10298
etc
Posted : 06/09/2015 11:27 am
In Windows rather than delete them I resize them to a much smaller size. Makes it easy to browse what's there and takes up negligible space. Should be possible on a Mac too.
Posted : 06/09/2015 12:35 pm
Using Terminal seems overkill, why not just open the folder, change view to list and sort order by Kind. Select the first and (shift+) select the last and delete?
Posted : 06/09/2015 1:29 pm
