Community
M4 blind fixing sug...
[Closed] M4 blind fixing suggestions...for timber
Wondered if anyone has a good suggestion before I take the 'bodge it' approach...
I want to fit 10 drawer type knobs to a piece of 18mm plywood, which is permanently fixed and doesn't have much of a void behind it. I only realised there was no access to the back after I bought the knobs and started to measure up where they needed to go!
So I've been hunting for a fixing to either take an M4 threaded rod, or to provide an M4 stud, so I can screw these knobs on.
Everything I can find is either a toggle style fixing or expanding wedge which needs a void. I have some kitchen unit style nuts but they are bigger than M4. One other option would be a bolt with an M4 thread on one end, and a self tapper on the other end, so it can screw into the wood and then take the M4 knob. I know you can get double ended self tappers but not seen a combined machine thread with a self tapper.
My bodge it approach is to chop the heads off the M4 bolts, drill some holes, and epoxy them into place. Just seems a shame to make the fixings permanent if I ever decide to remove them!
I also considered putting some M4 rivnuts into the timber but thats even more 'bodgy' and would be even harder to remove than epoxied M4 studs!
Posted : 05/09/2020 10:15 pm
An M4 threaded insert will do it. Widely available, a few different styles. These threaded ones are easy to fit: https://www.orbitalfasteners.co.uk/products/m4-x-10mm-type-d-flanged-timber-insert-nut-4mm-key-steel-zinc-yellow-plated
Posted : 05/09/2020 10:19 pm
And when you know what to search for, its as easy as that ๐Ÿ™‚ Thanks! Although I'm thinking, I could epoxy them in to start with, if they let go I can drill them out for the M4 inserts later on ๐Ÿ™‚
Posted : 05/09/2020 10:22 pm
these?
Dual thread screw is what you're after.
Ebay
Posted : 05/09/2020 10:27 pm
Epoxy. There is some great stuff out there real cheap. I have just used some for exterior balustrade mounting. I was dubious about the strength of drilling 14mm holes and filling with the resin before dropping in 12mm bolts but the stuff is amazingly strong.
You might only need a smaller weaker amount.
Posted : 05/09/2020 10:35 pm
thanks guys ๐Ÿ™‚
Posted : 05/09/2020 10:58 pm
T-nuts might be worth a look too? Use them in guitar cabinet building
Posted : 06/09/2020 9:48 am
I've get a huge bag of M4 T-nuts I used for a job which I only needed a handful for but a big bag was dirt cheap. If you want some give me a shout and I'll happily send you some. this style:-
\ https://www.westfieldfasteners.co.uk/Metric-Nuts/T-Nuts-4-Pronged-M5-Zinc-Plated-Steel.html?google_shopping=qty_BZP_Nut_4PrgTee_M5=20&gclid=CjwKCAjwkdL6BRAREiwA-kiczDLhoj1Vj3AVUFitKalI8xl69S2b3FMtgwN8fTJGTbF9Ag9Xw8zuMBoCop4QAvD_BwE
Posted : 06/09/2020 12:31 pm
T nuts are great but you'll need access from the back. If you put them in from the front they'll pull out easily
Posted : 06/09/2020 1:06 pm
All done... Didn't even need epoxy (yet) as a 2.5mm drill and then M4 tap seems to hold pretty well in plywood!
This has been a long time in the planning... I've now got a cab curtain that can blackout the van, help give the heating/air con a chance, no flimsy/stubborn curtain tracks, I can layer up the curtains to keep them out the way, or take them off completely rather than having a bulky curtain taking up space in the day :). And because I can fold them and layer the excess, they are long enough to hang off the cab shelf and enclose the whole cab when the front seats are swivelled ๐Ÿ™‚
Posted : 06/09/2020 1:45 pm
Good job. I was going to suggest similar but thought it might be too bodgy for you. Tapping works well in MDF. Done it a few times. Drill a hole, fill it with super glue, let it soak in, then tap it. Not tried it in plywood.
Posted : 06/09/2020 1:57 pm
