lower back pain fro...
[Closed] lower back pain from running
 mrmo
Finding that running is causing a little pain in the lower back, i am going to say at the top of the illiac crest as it does feel about that sort of height. I haven't been running very long and i accept that it is partially due to using muscles in ways they are not used to.
What are the possible causes and the possible solutions?
Posted : 28/12/2011 11:25 pm
Literally hundreds of possible causes and solutions.
Posted : 28/12/2011 11:36 pm
 mrmo
any chance of what are the most likely, and how they would be caused then, i can then think about what i am and am not doing to figure out what are the best ways forward.
Posted : 28/12/2011 11:39 pm
Have you had a proper running shoe fitting session?
Posted : 28/12/2011 11:40 pm
Poor core allowing your lumbar spine and sacroilliac joints to move around excessively, tight psoas major which would have a similar effect. Tight hamstrings, and tight erector spinae (the two big long muscles either side of your spine). Dodgy running gate. Weak glutes.
Basically due to a lack of conditioning.
Build up your running distance and more gradually.
Posted : 28/12/2011 11:43 pm
 Taff
As said above there can be numerous issues for me it's the muscles surround my lower back. Bit of stretching to keep them in decent condition and that does help.
Posted : 28/12/2011 11:45 pm
Tight hamstrings is my favourite from that list. Apparently they then tip your pelvis making the lower back sore. Stretch them out and also the muscles on your inner thigh.
Posted : 28/12/2011 11:51 pm
 mrmo
SbZ i do suspect the problem is being a cyclist, and the resultant issues.
Posted : 28/12/2011 11:52 pm
