If you wear contact lenses, and occasionally use 2 part epoxy resin, keep one or two of the plastic lens capsules, they're perfect for mixing small amounts - doesn't spread all over the card/paper.
My life will never be the same again.
U r lik Awzum!
My english is very no good. For which eye does it matter I put clear resin in and then yellow. Thanks you for life tip hacking.
*swoonz
Damned click-bait
rubbish, thought this was going to be about how to stop your lensing falling out
+1
is dizapont
Hack?
Do you take the lenses out of the little pots first?
That is a damn good idea. Congratulate yourself.
Anyone who uses the term Life Hack should be fired into the sun.
postit* note pads are better for mixing epoxy on. * other brands are avaiable
Yep, I use Postit notes and a match for mixing my contact lens adhesive.
There's biohacking now. OMFG.
In all honesty there's some substance to it - people already do it at a basic level i.e. coffee in the morning but not at bedtime, regular sleep, yoga, but it's being taken to another level by those twunks from California in order to promote 'gaining a cognitive edge in our knowledge-driven world'. All very TED and nothing to do with sticking an iDevice up your hoop (yet).
Read title. Put my lenses in. Then read thread. Balls.
I imagine epoxy might sort that out too
nedrapier - MemberIf you wear contact lenses, and occasionally use 2 part epoxy resin, keep one or two of the plastic lens capsules, they're perfect for mixing small amounts
I use them as water bowls for my pet dormouse.
A little bit of salt in one, little bit of pepper in the other - perfect travel condiment set if you're having a picnic for one.
To make space for condiments in my contact lens case I put my contact lenses in a spectacle case, then put my specs in a shoe bag, put my shoes in a hat box and put my hat in a wheeliebin.
Harry_the_Spider - Member
+1
I bought some shirts with those little plastic lolly sticks in the collar. I use them to mix up Araldite*. Have I dun a "life hack" too?
*not the shirts, the lolly sticks.
Floppy collars is what you've got, Dez..
Nothing floppy about my collars. Stuck some Araldite in em.
First offenders should[url=
get in the sea[/url]
Gives somebody a chance to come up with another useful like hack to stop collars going floppy ๐
He did it himself - Cloth Fibre Reinforced Epoxy Resin/Plastic Composite Collars.
He Never Had To Work Again After Following That One Weird Tip. Which was ironic, when he'd just sorted out his wardrobe of immaculately stiff-collared shirts.
Harry_the_Spider - MemberAnyone who uses the term Life Hack should be fired into the sun.
+2
Sunny holiday coming up for ned then! ๐
Daft comments on poor implementation of English aside, that's not a bad idea, I must have thrown hundreds of those away over the years, I'll keep a few around for just that purpose.
I must remember not to use two-pack epoxy to keep my lenses in place, though, I'm sure it'll lead to minor irritation...
๐
